Question about Kenmore 94499 Refrigerator
Spitting refrigerator suddenly my fridge spitts water all over glas shelves when in defost mode. Instead of water running down the back wall every thing that is on shelve gets wet. HELP.
    Novelist:
  • 114 Answers
HI ... TRY TO FLUSH OUT THE DRAIN LINE FIRST. SOME ARE ONLY VISIBLE BY LOOKING THROUGH THE BOTTOM AT THE REAR OF THE FRIG. THE TUBE IS SUPPOSED TO DRAIN INTO A PAN DOWN THERE. THE HEAT FROM THE CONDENSER EVAPORATES IT. GOOD LUCK
Posted on May 02, 2007
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
Water under the veg. compartment in sharp SJ-T520R-SL refridgerater
Hi,at the back of the fridge there is useuly a drain hole if its blocked then instead of the water going out of the back of the fridge its staying in the fridge,if there is one just get a peice of wire and push down hole to remove any blockidge,also what can couse itis if your food in the fridge is tuching the back off the fridge wall then the water runs down the food inside the fridge instead off going down the drain hole.
hope this was some help,all the best.
Apr 18, 2015 | Sharp Refrigerators
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
I have a micro fridge and the fridge is not cooling bt the freezer is cooling but not as it should i have the temp to the coolest and the fridge is still not cool what could it be?
it may be frosted up in the freezer behind the back wall, if there is frost build up on the back wall then you need to test the defost circut, termination therm, element and defrost timer
Jul 16, 2011 | Kenmore Side by Side Refrigerator
I have a whirlpool 363L WRN38RWG6, the problem i am having is that the fridge leaks water from the vent inside the door on top of the fridge section, then the fridge freezes any thing put to the back of...
I could not find the model but i assume it is a side by side.The model # should be located in the fridge side on the upper right hand corner on the fridge wall.On the freezer side in the back there is a cover with vents covering the evaporator coils. Remove the shelves,the cover to expose the evaporator.If the evaporator is all iced up your defrost themostat may not be working.The defost thermostat is located on top of the coils,it is a little round unit with 2 wires going to it.To check you can uplug it and put a jumper wire in the plug in to see if the defroster starts up.Make sure the fan is also working.Also check the drain (little round hole in the bottem of the drain pan) below the coils.Just poor a little water down it.If it is pluged you can use a small round tube and push it through the drain.Hope this helps,if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Refrigerators
Have a 6 - 7 year old Samsung RS2534WW from Best Buy. The back interior wall of the fridge is bulging forward/inward for quite some time now. We had to remove some shelving in order to be able to close...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Samsung RS2534 Side by Side Refrigerator
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
I have a problem with my powerpoint fridge/freezer water is always lying at the bottom of the fridge
this sounds like you have a blockage in the drain tube and when the fridge goes into the defrost mode the water will run down the back wall inside and lay under the cripsers. clear the blockage and it should fix the water problem.
Oct 15, 2009 | Refrigerators
Water on shelves in fridge and running down backwall of fridge
The drain from fridge/freezer down to evaporator pan in bottom of the unit is most likely plugged somewhere
Jul 02, 2009 | Smeg FR300SE 1 Top Freezer Refrigerator
Refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Apr 02, 2007 | Kenmore 74522 Top Freezer Refrigerator
Kenmore 94499 Refrigerator Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
