The question is, for my small portable Emerson color TV (which seemingly has no external Coaxial cord position), how do I attach a converter box or otherwise assure continued receipt of a signal when the change-over from ATV to DTV occurs ?  Is there a "live" telephone customer service person with whom I can possibly talk ?  (Phone number of Customer service ?)   I have a small (4 x41/2 ") portable AC/DC  2 Way Color Emerson Radio-TV combination, Model T00560 manufactured in Taiwan October 1990.  It works well as an "in the kitchen" unit.  I want to attach a "converter" box to the unit in preparation for the february change-over from Analog to Digital TV signal.  The unit has a bult-in single pole antenna or essentially a one-ear rabbit ear. As far as I can tell or see, the unit has no external positions for attaching a coaxial or any other cable from the "converter" box.  I have long since misplaced the "original instructions".   The question is, how do I attach a converter box or otherwise assure continued receipt of a signal when the change-over from ATV to DTV occurs ?
AThere is a port on the unit to install an outside anntenna so I'll head to Radio Shck with the set toi get the appropriare item....I hope.  Solution came from ustomer Sewrvice via Telephone though it took a20 minute wait for them to answer.
Posted on Dec 31, 2008
How to connect old vcr-plus to emerson tv
If the TV has RCA jacks on the back, use the red, white and yellow ports on the VCR to connect to the same colors on the TV.
Dec 18, 2014 | Emerson Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Have a 5" portable jensen tv/radio - no picture - how to attach a converter?
If it's one of the newer models that has the input for an antenna on the back then you can go buy the adapter at radio shack that allows you to hook it up with coaxial with either a converter box or a converter box with an antenna. The attachment looks like a 3.5 audio jack.
Oct 31, 2012 | Televison & Video
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
HANDHELD UNIT NEED ADAPTER TO GET DIGITAL SIGNAL NEAR KCMO
To connect a converter box to a handheld TV that has an external antenna jack, you need an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 12, 2009 | Casio TV-980 2.3 in. Handheld Television
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Casio EV 550 B portable TV 3" screen many of "us" with portables are wanting a "FiX" instead of landFILLing our sets when the switchover comes apon us. Is there a DTV FiX? costs? Are there portable DTV's?...
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that connects to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Jan 26, 2009 | Casio TV-980 2.3 in. Handheld Television
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
A few other tips:
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
Hand held casio tv vs digital signal
A few other tips:
Apr 29, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
