Question about Kenwood VR-6070 Receiver
Kenwood VR6070 speaker/amp problems
I am finally able to set up my surround receiver and the surround speakers won't work.
I was watching a DTS dvd to hear how it sounds and I noticed nothing coming from the surrounds. I ran the test tone and got nothing from the surrounds.
I disconnected each surround and hooked it up to the center channel output. Each surround worked in that setup. So it's not the speakers or the wire.
I connected the center channel speaker to each of the surround outputs and it worked in each instance.
I also tried to hook up the surrounds to the line-level B speaker outputs and didn't get a thing.
When it comes down to it, the B speaker output and the surrounds aren't putting out anything.
I will try using a separate amplifier and see it that helps...
I greatly appreciate any help you can offer!!
Unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Posted on Feb 09, 2009
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Rear surround speakers quit working from my Onkyo
It looks like the audio output was changed on the player so that it doesn't output 5.1. Enter the setup menu on the player and change DTS to output DTS instead of what be labled as stereo or L/R and Dolby Digital to output Dolby Digital instead of whatever else it is set to.
Jun 05, 2009 | Onkyo HTR500 Receiver
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Poor DTS/DD5.1 from the AVR-3801
I also run 2 AVR 3801`s in my home, These are nice receivers, excellent build quality, about the DTS and DD 5.1 not up to par, I would check the Menu speaker set-up, be sure and make sure you have rear surrounds set up at surround speakers, NOT the rear speakers, they are for a 7.1 configuration, then set up the white noise test signal to balance all 6 channels, you need to have the powered subwoofer balanced properely, if no results of improvement then check your digital connections, I would recomment the fibre-optic, but the coaxial works also with great seperation signal, last I would investigate the playback unit of the DVD or DTS CD player, something in your set-up is amiss and you can acheive outstanding surround with this model of Denon, I can attest to this for my past experience setting up HT systems even with High End Outboard processors I always am amazed at the 3801 output quality, remember the 5 ch stereo is a Matrix DSP not even close to a true digital sound, and as for more amp power sure it always helps to have extra but the 3801 are true 105w @ 8 ohm 0.05 THD and are real, should power you Missions, the next level are denons 4800`s and 5800`s at 125 and 175 but I would stick with the 3800 and be content. Hope you have some better results after tweaking your settings.
Feb 17, 2009 | Denon AVR-3801 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Full Surround Sound
Dear Jennis,
Have you set properly your input source? What about program mode on your playback on your amp was it properly set. You have to let the amp knows that you are using an optical cable for input, this must be done from the controls.
Sidlahora
Dec 06, 2007 | Kenwood VR-7080 Receiver
Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Oct 27, 2007 | Kenwood VR-309
Kenwood VR-6070 Receiver Logo
859 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
