Question about Harman Kardon AVR 7000
Right Front and rear speaker do not work proberly.
During listning to some dts music, suddenly the rigt rear and front speakers went to give less sound and the sound they give is that from a bad radio station. When i swich the audio cable teh same on the left side, so i think the problem is the complete right outpout.
I ran into the same issue with an AVR 7000 after it had been shipped to me. I took the cover of and found that the left and right amplifiers have a separate power plug into them. when I plugged to "bad" side back in everything worked great.
Posted on Jan 11, 2009
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
When I got my car there was no radio what i didn't notice was there was no radio harness at all. Long story short I went to the store and the ones they have don't fit the stock or after stock decks I have....
2003 Hyundai Elantra Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Gray/Orange
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Yellow
Left Rear Speaker Wire (-): Black
Right Rear Speaker Wire (+): Orange
Right Rear Speaker Wire (-): Blue
hope this helps out!
May 01, 2011 | Hyundai Motor 2003 Elantra
When i go to surround mode right front channel drops out
check for connection, might be the front right speaker was connected to right rear soround out, check recording if dolby pro logic or DTS system
Aug 31, 2009 | Denon AVR-3600
5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Feb 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
Not all speakers work in a LD 220 Surround sound receiver
Yes all speaker must be connected in order for them to work properly.  Also note that the audio that you are playing through it must be dolby digital 5.1 or higher or DTS.  If you are simply watching a tv program most of them will not be in surround sound as well as music discs.
Jan 06, 2009 | Gateway KAS-103 System
Color diagram for speakers
1995 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 24, 2008 | 1995 Ford Windstar
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Harman Kardon AVR 7000 Logo
607 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
