Question about Olympus Camedia D-390 Digital Camera
Battery Peoblem it was working find and now every time i put brand new batteries in it goes ti low battery and wont let me take pictures and only last for 30 mins and batteroes are dead wont turn back on.
    Genius:
  • 2,985 Answers
Are you using the correct type of batteries - normal alkaline are not powerful enough Do check out your manual.
Posted on Jul 17, 2007
Car wont start and i have a new battery
have the battery load tested as brand new batteries can be faulty. Check that the terminals on the battery are shiny clean and tight. Check battery leads are in good condition and not corroded away and check the earth wire is fixed and in good condition.
Feb 01, 2014 | Cars & Trucks
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
Goes through batteries very quickly....often reading "low battery".
run a pencil eraser over the battery contacts on the camera, it works most of the time
Sep 07, 2009 | Samsung Digimax 530 Digital Camera
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Nexia Q1 is flashing low battery when i put in brand new ones
Use alkaline batteries or rechargeable ones with over 1000mA
Dec 29, 2008 | Fuji Nexia Q1 APS Point and Shoot Camera
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Olympus Camedia D-390 Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
