THe washing machine fills and empties however the drum does not spin, the belt is intact and on the spindles.You can hear the machine going through the cycle however the cycle does not finnish the clothes were removed whilst the clothes were wet although the drum was empty of water.
I suspect the motor is not working how can you check this out.
we have a frigidaire full size laundry center.model # GLET1041AS1.It has started leaking during wash...
(More)
we have a frigidaire full size laundry center.model # GLET1041AS1.It has started leaking during wash cycle, and it sounds like a bearing is slipping. the noise is loud. It is a washer dryer combo. Is this a major repair as far as cost.?
hotpoint aquarius Just put on the tumble drier and three lights flash on the left hand side and the...
(More)
hotpoint aquarius Just put on the tumble drier and three lights flash on the left hand side and the dry and stop start lights flash
I have a 9 year old siemans washer/dryer which has recently developed a mind of it's own. It stops...
(More)
I have a 9 year old siemans washer/dryer which has recently developed a mind of it's own. It stops during a wash cycle, if I switch it off and on again it starts and completes the wash but stops during each rinse cycle, again I have to switch it off an on every time. It doesn't do it quite so often if I use the higher water level button
