Question about Samsung RS2534 Side by Side Refrigerator
Samsung Refrigerator Model RS2533SW - Ice Maker Stuck
The ice maker is stuck in the flipped (down) position when it last dropped ice cubes. I tried the reset button but it does not move. There is a small amount of ice accumulation at the front of the unit where the ice drops down to the dispenser. Does anyone have information on this issue?
  • Todd Born
    Todd Born May 11, 2010
    can you try to totally remove the ice maker from the freezer? lift the black button up and when you do this slowly pull the ice maker forward and it will come loose. then disconnect the wires that go to it and totally remove the-ice maker. Then let it thaw out and make sure that nothing is binding the ice maker. Replacement is the same except opposite and when you get it back in press the reset button on the bottom right and the maker should reset. Good luck and don' t forget to rate this answer please. Thanks for using FIxYa!!!
  • 700 Answers
Did that work?
Posted on Feb 04, 2009
    Problem Solver:
  • 5 Answers
I did this but found it still didn't work till I turned the fridge off at the mains. Now working fine. Many thanks
Posted on Aug 10, 2009
  • Huu LE Jul 09, 2013
    I have this problem too, can you tell how to turn the fridge off at the mains and how long before you turnit back on. Thanks
Ice maker not making ice in whirlpool model #wrx735sdbm00
Check the Ice Maker itself (not the bowl). Is there ice cubes stuck in there? If so, that means that the ice is stuck and the the "pusher" doesn't have enough force to drop them into the bowl.
Mar 11, 2014 | Whirlpool GC5SHEXNS Side by Side...
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
Ice maker is not working
check that the ice maker arm is not in the up position or has come dislogded. if the metal wire is dislodged use a mirror to help put back in the ice maker. put it back in the round white area with an elongated slot. flip down if off. check the ice maker to see if an ice cube got hung up and is jamming it. check with eyes and fingers. last the ice maker will not cycle if the door switch is not activated. this check requires you turn off the ice maker with the arm. come back in 6 hours put the arm back down and hold door switch and see if it starts.
Apr 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice bale will not drop down. It is stuck in the up position
heating element is bad and dose not heat to relase the ice .. replace ice maker is what usally has to be done....
Aug 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice turning into a solid block in freezer. Samsung Refigerator
when you look into the freezer where the ice maker is do you see something hanging underneith the ice maker? if you doi that is the sensor. If not contact me and I will walk you thru the steps to correct the problem.
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Samsung RS2534 Side by Side Refrigerator Logo
2,794 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
