Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Computer turns on automatically when i plug in the power supply
And i get no Bios screen or beeps, or warning's what can i do to fix this ??? I have a Intel Celeron 2.50 processor and 512 meg of ddr memory 250 watt power supply, has same mobo as in this query.
  • 1 more comment
  • marcperez200 Jan 15, 2009
    same problem. please help!
    mobo: asus p4ge-mx
    i tried running only RAM, CPU, PSU, and video card, nothing... still no display
    I tried replacing the PSU, same issue... all 3 times
    it started with a psu that plugged in and just randomly turned on by itself without using the power button. CMOS wasn't even plugged. I tried replacing battery aswell... and still turns on after i switch on the PSU
    the mobo LED light blinks which is pretty abnormal... the PSU that started this killed another computer. so whats happening?
  • captainbigda Apr 01, 2009
    Motherboard / fans/ soundcard dead or not properly functioning. had a gateway & it crashed(550mhz intel 3). A friend gave me an emachines T-2642 with good parts. Used Some gateway parts & got it working. It powers on when u plug it in/wont shut off/ no sound or video. Power supply & fan works/disk drives -floppy & hard drives all power up. just no sound video & internal processor fans not working!! HELP!!
  • pklinuxguru
    pklinuxguru May 11, 2010
    If I understand you correctly, whenever you plug in power, the power supply starts up, but then you don't get anything like it's booting up. Is this something new it's started? There is usually a on/off switch on the power supply beside/above/below the power cord connector. If it's off, it shouldn't power up. Have you put it together yourself or recently upgraded the MB or CPU? I haven't tried this, but maybe the power switch connection on the MB is opposite what it should be or even on the wrong jumpers.
    Scholar:
  • 172 Answers
Hi, i am an emachine specialist,
do you get the following:
cpu cooling fan running ?
hdd heard to be running
cd/dvd devices operational?
no picture on screen ?
compdoctor2005@btinternet.com
Posted on Jan 01, 2009
    President:
  • 948 Answers
250 w is a rather low wattage power supply. That's one thing I would change if you have spare parts available. Here is what I would try:
Remove the memory and blow the dust out of the system. If you have more than one memory chip, put only one in and attempt to reboot. If that does not work, swap memory chips and try again.
Good luck.
Posted on Dec 31, 2008
My Dell laptop makes 12 beeps and won't start, why?
Unfortunately, they are bad news and omens of *****!
  • Beep Codes - General Hardware - Laptop - Dell Community en.community.dell.com > ... > Laptop > General Hardware There is a comment in the User's Guide that you should make a note of beep codes when contacting Technical Support but there is no list of the beep codes - this ...
  • Dell Optiplex and Vostro Beep Codes and Error Messages ... www.dell.com/support/Article/us/en/19/SLN143065/EN 1. OptiPlex Beep Codes. The computer might emit a series of beeps during start-up if the display cannot show errors or problems. This series of beeps, called a beep ...
  • Beep Codes and PSA Diagnostic Chart - Desktop Wiki - Dell en.community.dell.com > Support Forums > Desktop > Desktop Wiki Identifying Dell Computer Models Using the Model Code. On Sept 26, 2005 the System Setup program on certain Dell Dimension™, Inspiron™, and XPS™ computers was ...
  • Alienware Computer Does Not Turn On or Go Into Windows ... www.dell.com/support/article/SLN114868/en Dell support article tagged with ... The following tables illustrate the Beep Codes for Alienware Mobiles and ... For a laptop computer see if you can access the ...
  • Dell Inspiron 15R (N5110) Beep Codes Diagnostic Indicators blog.parts-people.com > ... > Inspiron 15R (N5110) How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming ...
  • Dell Motherboard Beep Codes - What They Mean www.brighthub.com > ... > Computer Hardware Support 2010-05-23 · Technicians and computer users alike can use beep codes to troubleshoot hardware problems on all kinds of machines. This article lists Dell beep codes ...
  • Dell BIOS Post Codes - BIOS Central www.bioscentral.com/postcodes/dellbios.htm Dell BIOS Beep Codes; Dell BIOS System Messages; Dell BIOS Post Codes . Dell BIOS Beep Codes:
  • Step-By-Step: Deciphering BIOS beep codes - TechRepublic www.techrepublic.com/article/step-by-step-deciphering-bios-beep-codes Discover what the beeps your computer makes at start up mean. ... Step-By-Step: Deciphering BIOS beep codes. ... Dell BIOS Beep codes for Dell computers ...
  • http://www.bing.com/search?q=dell+laptop+beep+codes&qs=AS&pq=dell+laptop+beep+codes&sc=2-22&sp=1&cvid=768D6F3CC9284B039CE5B3AB707EFF02&FORM=QBRE
    Jul 31, 2016 | Dell Computers & Internet
    Medion NoteBook :LT 9886 The "Battery
    The battery is shot and needs replacing.
    Jun 30, 2008 | Medion Computers & Internet
    Can not turn on my emachine desktop tried unpluging but still will not turn on
    check the following list first
    - 1 unplug the power cord from the computer, hold the power button for 10 seconds, plug it back in and power up the computer. (go to item 2 if this fails to solve problem)
    - 2 power on the computer and listen for a beep sound at least one time (if no beep sound, then you have no post meaning a bad BIOS or a broken Motherboard) - (if this is the case replace motherboard else Move to Item 3 if N/A)
    - 3 Power on the computer and make sure that the Power Supply fan is spinning ( if not then replace power supply) - ( move to item 4 if N/A)
    - 4 If when powering on the PC you have a POST / beeps but no Video then count the amount of beeps ( shorts and longs beeps) in the same order the hear them, go to you pc manufacture and in the support section look for specs and find what bios chip it has, then go to google and look for your Bios Post Beep Code Errors
    - you may find a defective / broken video card or bad RAM / Memory
    Good luck.
    Apr 22, 2011 | Computers & Internet
    Video adaptor giving beep code on post Asus M/B M2NPV-VM 1 long then 2 short beeps also has a usb over current issue at post but has no usb pluged in. please help me decifer this. thanks in advance troy
    This is a fix that worked for me, however I cannot tell you why or even feel that I had done anything which would constitue this as a fix. I leave my PC on 24-7 and came in one morning and it was locked up. Couldn't get a video screen, not even reset worked so I threw the power switch on the back of the power supply. Turned the switch back on and pushed the power up button. The MoBo started 1 long and 2 short beeps, repeating. I pushed the reset button and same thing. I again turned the power supply off, then on again and same thing with the beeps. So this time I turned the power supply off then also un-plugged the power cord to the power supply. I left it that way for maybe 10 minutes, while I did a few other things. I plugged the power cord back in, turned the power supply back on and hit the power up button. My PC booted up...no problem. ???
    Point is - this issue as reported by others may just be a hardware or bios fluke and needs a power reset or maybe even clearing the bios and restarting. Reseating the memory sticks, use just one memory stick and rotate the memory sticks to sort out the possible bad one and reseating the processor may also help.
    Oct 12, 2010 | ASUS M2NPV-VM Motherboard
    I just bought it off of craigslist hoping to fix
    with nothing happening it is very possible the hard drive that needs replacing or is missing
    Mar 24, 2017 | Gateway CX2610 Notebook
    HP Pavilion 7965 not booting: Just replaced PSU with one that works just fine (got it w/o a power supply) and after checking all connections, powered it on. It turned on and immediately beeped for about a...
    You have to have ram memory in, for the computer to operate at a basic function. To get to the BIOS POST screen.
    NOTE*
    When changing out hardware do you have the power disconnected from the computer?
    Yes, I know, but I have to ask.
    Also, do you follow anti-static precautions before sticking your hands inside the computer?
    Touch the metal frame of the open computer case before reaching inside?
    Your body carries Static electricity.
    Static can fry out the hardware components inside your computer.
    Especially the Processor, which is the most susceptible hardware component to static shock.
    1) Computer unplugged from power. Video card removed. Monitor plugged into VGA port on the motherboard. Ram Memory installed. Harddrive data (Interface) cable disconnected, and power cable. Same for any optical drive/s.
    Press the Power On button in, and hold it in for a count of Five seconds.
    Let go.
    Do this procedure 2 more times.
    What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings.
    Plug back into power. Wait 1 minute. Turn the computer on.
    Do you get the BIOS POST screen? Let's start from here.
    Feb 28, 2010 | HP Pavilion 7965 PC Desktop
    Power pack lights up fans turn on computer wont power up
    Sounds like motherboard is not getting correct power. Could be as simple as installing a new power supply ( try tigerdirect.com for supply) or it could be as disheartening as a cracked motherboard. These are tricky problems, does your computer beep at all during startup? If it does find out the manufacturer of your bios, and look up the beep codes for that brand. Every bios has different beep codes that could be trying to tell you something.
    Aug 01, 2009 | Acer Computers & Internet
    Beep sound continus
    I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
    Standard Original IBM POST Error Codes
    1 short beep Normal POST - system is ok
    2 short beeps POST Error - error code shown on screen
    No beep Power supply or system board problem
    Continuous beep Power supply, system board, or keyboard problem
    Repeating short beeps Power supply or system board problem
    1 long, 1 short beep System board problem
    1 long, 2 short beeps Display adapter problem (MDA, CGA)
    1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
    3 long beeps keyboard card
    Each BIOS company has modified these codes over the years.
    May 25, 2009 | Dell Dimension 4600 PC Desktop
    Computer freezes during startup
    Hi, This is typical when the motherboard (CMOS/BIOS) is having a difficult time auto detecting the devices installed including drives, videocard, sound card, network, etc. Initially set your CMOS/BIOS to default/fail-safe settings, save & exit. Perhaps you can try running with the barest of add-on devices as you have posted initially, but do it one step further, remove everything including that one last HD (with the correct jumper settings). If you have onboard video use that one rather than an AGP or PCI-E add-on. Run the unit with just a single memory. No cables other than power and front panel. Thereafter connect your devices one by one and try every time a new one is added. This include removing any USB devices/cables plugged in. More often it is an add-on that causes freezing at this point as you have described. You may also venture in trying to flash your BIOS (however pls be forewarned of possible difficulty/failure when doing so). Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
    Sep 30, 2007 | MSI : 661FM-L P4 SIS661FX FSB800...
    Computers & Internet Logo
    3,653 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
