Question about Acer Aspire One AOA150-1570 Notebook PC
Fan noise Fan sounds like a 747 taking off when starting up. What can I do?
    Problem Solver:
  • 7 Answers
As long as it is not making any grinding noises, thats good. its keeping your notebook cool. notebooks have a nack for over heating.
Posted on Dec 30, 2008
Noise in front of vehicle
check if you have a viscous fan hub. If you have it will be that the hub has started working while you were stationary to raise up the fan speed to assist in cooling and when you rev up to take off the increase rpm increases the fan noise and when the air is passing through the radiator the hub cuts out and the fan noise goes.
Nov 22, 2013 | 2005 Chevrolet Tahoe 4WD
What revolutions should my 4 litre v6 Hi lux Surf be doing on start up in the morning and how quick should it drop back to normal idle?
concerned about nothing
the ECM sets the high idle rpm on starting so that there is sufficient air / fuel mixture to keep the engine running while it does a tune up and checks all the sensors
when the sensors are all reporting within parameters , the idle speed will drop back
should settle at around 850-900 rpm
as for the fan noise
if you have a viscous fan hub( not electric ) that is the fan locked in high temperature mode and will stay there until the liquid silicon is pumped back into the reservoir
usually takes about 1 minutes and indicates a properly operating fan
as the silicon is being pumped back the fan rpm slows down with a reduction of fan noise
If anything raises your concerns , you have an on board fault recording system that you can access at any time using a scan tool
get in the habit of having the fault codes read at each service or when you feel something is wrong as it will save you lots and lots of cash by not guessing repairs
Dec 12, 2017 | Toyota 4Runner Cars & Trucks
How many types of bearings are in the front end?
Clunking going slow sounds like u joints bad in the driveshaft(s). Engine has idler pulley and air conditioning clutch bearings, alternator and power steering pumps have bearings, bearing in clutch on fan can go bad making noises at slower speed. Noises only while driving are drive train related. Try another mechanic's diagnosis.
May 11, 2017 | 1998 Plymouth Grand Voyager
Why does my kenmore refrig. sound like a jet plane taking off! It does not do it all the time and if I shake it real hard it stops. makes ice fine stays cold with no problems. Just sounds like a 747...
depending where the noise comes from check the bottom fan motor and try to put some WD40 or any other lubricant on front bearing or inside the freezer fan motor do the same remove the front cover and you should see it...........good luck
Jun 15, 2011 | Kenmore Refrigerators
My dimplex fireplace is too noisy. It's been that way from day one. We should have sent it back, I guess. Everything else is great about it but it sounds like a 747 jet!
I have been dealing with electric fireplace/heaters for several years, now. And for the life of me, I can not think of a thing that would cause a noise like a 747 jet plane. Could you be a little more specific as to which function of the fireplace cause this noise?
Look forward to hearing from you.
Apr 05, 2011 | Dimplex DGWH4031 Heater
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
I have a hobart crs 103 that makes a verry loud noice. It works but it sounds like a 747 taking off. Any qlue
Sounds like a fook,knife, spoon is caught in the pump.I'm a hobart tech and repair them often.Can you tell where the noise is coming from?Let me know.
Nov 17, 2009 | Hobart Dishwashers
My machine make too much noise
does it sound like a 747 about to crash in your house? if so you might as well through your washer away because you have a bad bearing and the cost to repair that is about the same for a new one. let me know if this helps
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fan belt is broken. Need part for model THC09K34STC
This company is suppling me with part for mine.
hope this helps for model THC09K34STC
The Gabbert Company
6868 Ardmore
Houston, Texas 77054
Hours ... 8:00 am to 5:00 pm Monday through Friday
Email:sales@gabbertcompany.com
Phone 713-747-4110
800-458-4110
Fax 713-747-0192
Good Luck
Apr 14, 2008 | Friedrich Heating & Cooling
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
