Question about Vivitar ViviCam 5385 Digital Camera
Problem with my digital camera
My Camera has the screen on black it takes picture but the come out all blk do you know is I can fix it myself?
  • 3 Answers
Replace CCD unit in the camera, vivitar are the only ones that should do that but aparantly they charge you for it. The CCD unit in the 5385 is a common fault in the camera.
Posted on Sep 16, 2007
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
Black screen only when taking pictures
The link below should be helpful to fix your camera issue.
Camera Troubleshooting Link
Regards,
Sean
Jun 08, 2013 | Canon PowerShot S5 IS Digital Camera
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
Canon SD1000 shows black screen when trying to take a picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
I had my camera for a couple of years and the lcd screen went black, i can't take new pictures anymore.
If the screen goes black, you can still take pictures. There is no way to fix the black screen, it just blew out.
Jun 16, 2009 | Canon PowerShot A620 Digital Camera
Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Nov 11, 2008 | Canon Rebel XTi / EOS 400D (body only)...
Canon S215 viewfinder and lcd display screen blk
It may be fixable, but it may be expensive. You also have the option to upgrade your camera through Canon's Loyalty program. I'd give them a call and find out what your options are before going out and purchasing a new camera.
Apr 11, 2008 | Canon PowerShot S2 IS Digital Camera
My PowerShot A620 lens isn't working
Don't even try unless you know what you are doing - you can get a nasty belt off a charged flash capacitor (around 300volts) - the lens is more than likely clogged up with sand, this will wear the sliding tracks in the zoom very quickly and will render it useless.
You can buy new lens assemblies (Colchester Camera Repairs) but the cost will be high, around £80.00 just for the part.
Jan 01, 2008 | Canon PowerShot A620 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
69 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
