How can I resolve this issue: Communication Failed. Make sure that the power is on, the cable is firmly connected, and the scanner is not use by another application. For details refer to FUJITSU TWAIN 32 Scanner Driver User's Guide. (Code: DS42019)
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Fujitsu scan snap wont scan
Hello Angela,
You need to check the followings:
1. Check the power supply and make sure that the scanner is powered on and is detected on your computer.
2. Check the USB cable for connectivity of the device to the PC.
3. If everything is ok, reinstall the scanner driver and see if the issue is resolved.
Thanks,
TechSatya
Jun 22, 2012 | Office Equipment & Supplies
1.scanner power is on 2.cable is firmly connected
When the scanne: 1.scanner power is on 2.cable is firmly connected what to do?
Dec 02, 2011 | BenQ Scan to Web 3300U Flatbed Scanner
My tv power light is blinking and the tv wont turn on.
To resolve this problem, follow these steps:
  1. Make sure that the power cord is firmly connected to the wall and the TV.
  2. Make sure that the cables connecting the TV to the various video sources (cable, set-top-box, DVD player, VCR, etc.) are all firmly connected.
  3. Make sure that the source you are trying to watch is turned on and/or providing a signal.
  4. Turn the TV off, and then on.
  5. Press the Source button on the remote, and cycle through the sources.
If this procedure does not resolve your problem, most likely the power supply is failing and you need to get your TV serviced.
Jun 01, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
The picture doesn't appear..plz help (not hdmi) evry thing else seems fine.
If you have already checked to ensure that the cables are firmly connected, the nest thing to try is another cable of the same type to see if the cable is the problem. If that doesn't resolve the issue then try and let the PS3 find the proper resolution automatically. Make sure your cables are firmly connected. Then turn on the POWER with the switch on the unit not on the remote. Keep holding down the power button until you hear a beep which should be about 5 seconds. You may have to try it a few times until you hear the beep. The PS3 will then automatically sense the cable connection as well as your display's native resolution. If that doesn't work then you likely have an internal issue. Unfortunately there are a number of problems that can cause the audio no video issue. At that point you would be better off having your local PS3 shop do a diagnostic on your machine. Most shops will probably charge you an hours labor to do the tests
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
No video but have audio
If you have already checked to ensure that the cables are firmly connected, the nest thing to try is another cable of the same type to see if the cable is the problem. If that doesn't resolve the issue then try and let the PS3 find the proper resolution automatically. Make sure your cables are firmly connected. Then turn on the POWER with the switch on the unit not on the remote. Keep holding down the power button until you hear a beep which should be about 5 seconds. You may have to try it a few times until you hear the beep. The PS3 will then automatically sense the cable connection as well as your display's native resolution. If that doesn't work then you likely have an internal issue. Unfortunately there are a number of problems that can cause the audio no video issue. At that point you would be better off having your local PS3 shop do a diagnostic on your machine. Most shops will probably charge you an hours labor to do the tests.
The Scanner now has a pink line down the page - when I save a scan it has the pink line! Can this be fixed easily or should I buy a new All-In-One? I really like the HP 7410 -great until now.
I always advice my customer to follow below steps if a vertical line are encountered while scan or copy.
SOLUTION ONE: Reset the All-in-One
Power Reset:
If there is static interference, or loose connections with the product, this can result in bands or lines in
the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
1.Make sure the product is powered on, and then disconnect the power cord from the product.
2.Disconnect the USB cable from the product, and then disconnect it from the computer.
3.Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4.Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5.Reconnect the power cord to the product.
6.Press the Power button to turn on the product.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists, see the next reset.
Partial Reset
1.Remove the power cable from back side of the printer while its ON.
2.Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
3.If printer turns OFF, press power button to turn it ON.
Semi-Full reset
1.Remove the ink cartridges.
2.Remove the power cable from back side of the printer while its ON.
3.Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
4.If printer turns OFF, press power button to turn it ON.
5.Insert the ink cartridges.
NVM Reset
1. Remove the ink cartridges.
2. Remove the power cable from back side of the printer while its ON.
3. Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
4. If printer turns OFF, press power button to turn it ON.
5. Insert the ink cartridges.
If the issue persists, see the next Solution.
SOLUTION TWO: Clean the product and make a blank copy
If the scanner glass or the white underside of the lid has debris, this can slow performance and affect copy
and scan quality. To resolve this issue, clean the All-in-One.
Before you begin, gather the following materials:
*Several clean, soft, lint-free cloths
*Mild glass cleaner
1. Press the Power button ( ) to turn off the product, and disconnect the power cord from the product.
2. Open the scanner lid.
3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
CAUTION:Do not spray the glass cleaner directly on the glass to avoid damaging the scanner.
4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
NOTE:Do not use tissues that can leave fiber residue.
6. Clean and thoroughly dry the small strip of glass to the left of the scanner glass, and then clean and dry the white plastic strip on the left underside of the scanner lid.
7. Close the scanner lid.
8. Reconnect the power cord to the product, and press the Power button to turn on the product.
If the issue persists, please service the product.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Carriage jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Oct 27, 2008 | HP ScanJet 4500C Flatbed Scanner
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
2,101 people viewed this question
jasbo
jasbo
