Question about IBM NetVista PC Desktop
Hard drive not found
Have replaced hd wtih a new one,the hd shows up in the bois,but when i go to install operating system,get a message that says no hard installed.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What do you have your boot sequence set to in the BIOS? Make your CD/DVD drive first (or second if you have a floppy drive and make it first) and the HDD last.
    Novelist:
  • 124 Answers
Wayneard is correct. When you install a brand new hard drive as the ONLY hard drive in the computer, there is no operating system loaded. The computer will try to boot from the hard drive and stop. Switch your boot order to have the CD boot first, and be sure you have the operating system installation CD in your CD drive.
Also, double check your hard drive connections. Be sure it is in the "master" position on the hard drive cable. If there is a connection problem, the system will complain after CD start that there is no hard drive available to install the operating system on!
Good luck.
Posted on Dec 30, 2008
  • Gary
    Gary Dec 30, 2008
    Oh, and of course, after you have installed the operating system, remove the installation CD. You don't have to change the boot order, as the system will find the operating system on the hard drive, but you can save a few seconds off the boot time by switching to the hard drive as the first boot device.
  • wd neojoneswd
    wd neojoneswd Jun 24, 2014
    gary is right. also, the boot from you dvd/cd will ask if you want to format the new HD, you will so click YES.
ACER ASPIRE 4710
This will occure for a couple of reasons.
1. Your hard drive has gone bad or the connectors have.
2. Your bois is set to boot from the network card, and not the hard drive.
1. boot to the bois, and look to see if it "sees" your hard drive. If not replace the hard drive. This will require you to install the OS and software.
2. Boot to the bois, check the boot order and remove or disable boot from LAN or PXE. If this is the problem you should now boot from the hard drive, if not you will probably still get the no OS found error indicating a bad hard drive (see 1 above).
Hope this helps
Jun 27, 2012 | Acer Aspire One PC Notebook
Boot up issues
You need to look in the Bois at the boot options. Select for it to boot from CD/DVD rom first (optional for booting from CD/DVD to reload os) second boot device would be the hard drive. Next see if you can disable the network or ethernet boot.
The indication above is that you have network or ethernet boot as an option for booting in the bois. If the boot order is simular to what I have listed above (network last), then your hard drive could be failing. Run a hard drive test and if it fails testing, back it up right away and replace it with a new hard drive.
Hope this helps
Mar 20, 2012 | Computers & Internet
MacBookpPro osx10.4.11 doesn't recognize new WD passport
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
//javaftper
Apr 02, 2010 | Western Digital Passport WDXML800UE...
HI, I try to install new hard drive, but it show me operating system not found (because is nothing there,it's new HD), I install recovery cd and restart computer, must start recovery cd,but processer...
Your new HD needs to be formatted and partitioned.
Here is a link to a free and SAFE program that will format your new drive:
http://www.seagate.com/www/en-us/support/downloads/seatools
Once you format the HD, your recovery cd will be able to find it!!
Contact me if you need help with the SeaTools.
Oct 09, 2009 | Sony VAIO FRV37 Notebook
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
May 13, 2009 | Acer Extensa 4620 Notebook
I PLUG IN A BRAND NEW WESTINGH. HARD DRIVER 160 GB AND COMPUTER S
did you configure the 160GB hard drive as second???
there is a shorting pin between the ribbem cable and the power cable.
take a look on the hard drive, there should have adiagram shows where the shorting pin need to go to make it as secondary drive.
install the hard drive as secondary drive.
if you want the drive to be the primary. you nee to install the operating system on it.
with out operating system the machine will boot up in to DOS only, and a error message telling you the drive has no loader.
Nov 12, 2008 | Dell Inspiron 2200 Notebook
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
IBM NetVista PC Desktop Logo
187 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
