Question about Asrock P4i65G Motherboard
New motherboard i have changed my motherboard and the system panel header is with 9-pin panel my panel have 6-pin two of my pins going to power on off and another four pins going to power led and hd led. what i must to do run on my new motherboard...?
    Novelist:
  • 101 Answers
You don't say what case you are using. If it is proprietary and the front panel header is all in one connector, you can carefully back the connector pins out of the block using precision screwdrivers. I keep a bunch of two pin connectors from junked machines so I can create individual connector sets when changing motherboards (eg, PWR SW, PWR LED, HDD LED and RESET). This also requires that you know the pinouts of both the old board and the new one so you can get everything connected properly.
Very doubtful you will ever find an adapter to change from one front panel block to another.
The 9-pin connector probably uses a spacer pin between the legs of the PWR LED, while it seems the 6-pin does not have RESET.
Posted on Dec 30, 2008
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3440614&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3440614
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
Regards,
joecoolvette
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Starting on the Right side at the Top, going down,
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
Wire diagram
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Specifically we are talking about the Reset switch, Power On switch, HarDDrive activity LED light, and Power On LED light.
Speaker pins for an onboard speaker< (BIOS Beep Codes), may be also included in this header.
What you need is a Front Panel header pinout.
I'm looking at the motherboard now,
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/6335.jpg
The silkscreen print next to the Front panel header, is fuzzy. Probably is on your motherboard also.
[Motherboard installed in computer case, the Front panel header is at the Bottom/Right corner. Just wanted you to know, I KNOW.
The photo has the motherboard turned 90 degrees to the Right.
PANEL is silkscreened to the Right of the Front Panel header ]
Looking at the motherboard installed in the computer case, the Front Panel header is two rows of pins.
The pins have a white rectangle silkscreened around them. To the left of these two rows of 10 pins, is another small rectangle in white.
These are for IrDA,
(6 pins. Two rows of 3 pins)
http://www.webopedia.com/TERM/I/IrDA.html
Suggest leave them alone.
There are 20 pins. Two rows of 10 pins for the Front panel header.
Willing to bet Pin 1 is the pin to the upper Left corner.
Pin 20 is the pin at the bottom Right corner.
Coming from the Left side, across the Top row;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Coming from the Left side, across the Bottom row;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
It looks as though this is just the old Front Panel header setup, used for a lot of old motherboards.
For example, I can just about make out the pins for the HDD activity LED light.
Bottom row, come from the Left side.
The first three pins, which are pins 2, 4, and 6, are for the Keylock.
DO not connect any wires to them!
The next two pins, 8 and 10 are for the HarDDRive activity LED.
Top row; Pins 5 and 7 look like they are for the Power On LED.
HOWEVER, let's use deductive reasoning based on intelligent thought.
Or in otherwords, 'Wing it'.
All you have to do, is get one of those LED lights that have two wires.
This will be your test unit.
Go across the Top row. Touch TWO pins at a time. For example Pins 1 and 3. No power? Touch pins 5 and 7. No power?
(Shouldn't be)
Touch pins 9 and 11, and so on. Keep going across the Top row.
No good? Go across the bottom row, BUT SKIP pins 2 and 4.
What will happen? When you finally touch, the two pins for the Power On switch, the LED light will light up, and the Power Supply will turn on.
With the Power Supply on you can go back, and see which two pins keep the test LED light ON. These pins will be for the Power On LED.
Test LED light blinks? You are touching the pins for the HarDDrive activity LED.
Windows is running, and you touch two pins, and Windows restarts?
You have the pins for the Reset switch.
Speaker pins will be FOUR pins in a row, and by finding the rest of the pins, you will know which ones these are.
BY using the LED light you will harm NOTHING. In fact you could use a jumper wire. If you touch the wrong pins, NOTHING will happen. If you touch the two pins for the Power On switch, the Power Supply will come on.
Shock Hazard:
The VOLTAGE is 5 Volt DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
In otherwords; NONE.
It may be hard for you to navigate around this website, but would appreciate hearing back from you.
Perhaps you can post a Front Panel header pinout, for this motherboard, and be somebodies hero.
Just a thought.
Regards,
joecoolvette
Jun 22, 2012 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
How to connect power to the front panel
Power to the Front Panel?
A) The plastic front of your computer is the Front Panel
B) The area of pins sticking up on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
I believe what you are requesting is the Front Panel header pinout.
AsRock Support > AsRock 775i65GV Motherboard > Main Support Page,
http://www.asrock.com/MB/overview.asp?Model=775i65GV
Go to the headings on the upper left side.
Products, Motherboard Series, 775i65GV, Overview and Specifications, and so on. Click on - Manual
On the next page go across from the heading - User Manual, and click on - Click Here, under the country nearest yours.
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to arrive at the page you want, or;
1) Put your mouse cursor in the page number box.
2) Left-click once. (Contents in page number box will be highlighted in blue)
3) Type the page number you want in the page number box.
4) Press the Enter key
Go to Page 10
This page shows an illustration of the motherboard, and as it sits in your computer case.
To the bottom Right corner is the Front Panel header. It is marked by the number - 16 [ System Panel Header ( PANEL_1) ]
{ It is the second header over from the Right side. It is Black in color. The first header is a USB header, and it is Blue }
Now go to Page 22. Front Panel Header Pinout. (System Panel Header pinout)
If you cannot download this motherboard manual, or if you do not understand the pinout;
There are 4 pins across the Top row.
There are 5 pins across the Bottom row.
The Top row of pins are numbered Even
The Bottom row of pins are numbered Odd.
Starting at the LEFT side going to the Right, on the Top row;
Starting at the LEFT side going to the Right, on the Bottom row;
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
IF the LED light is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset Switch, IF, a Reset switch is used.
Pin 5 is for Ground ( - )
C) Pin 9 is Not Connected. (N/C)
D) Pins 2 and 4 are for the Power On LED light.
If the LED light is dim, switch the two wires around.
Page 21 details out the USB front panel headers, (USB 2.0 Header, Shared USB 2.0 Header), and the Front Panel Audio Header.
Regards,
joecoolvette
Dec 26, 2011 | Asrock 775i65GV Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Starting at the Bottom on the Left side going Up;
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Asrock P4i65G Motherboard Logo
260 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
