Question about Linksys Wireless-G WRT54G Router
Need to open ports 3724/6112
Linksys router wrt54gs
  • 3 Answers
You need to login to the router, go to the applications and gaming tab and then enter the following information into the first two empty lines on the list of ports to forward:
WOW1 / 3724 / 3724 / Both / (your IP address) / Enable
WOW1 / 6112 / 6112 / Both / (your IP address) / Enable
Click on "Save Settings."
You'll need to make your IP address static on your PC for this to work. Since the WRT54GS doesn't allow DHCP address reservations, you'll have to do this manually in your network setup on the PC.
Reply back with your operating system version if you need help with this.
Posted on Dec 31, 2008
Need to open 1900UDP on the AT&T router so my Bose sound touch portable will work
Go to the Linksys website
http://support.linksys.com/en-eu/support/routers/WRT54GS
Click "Videos" and check out the port triggering-video.
You might want to check if the port it blocked in your firewall aswell.
Nov 09, 2013 | Linksys Wireless-G WRT54G Router
Tip
How to find the MAC address of a Linksys WRT54GS wireless router
If you have a Linksys WRT54GS wireless router and you need to find its MAC address for some reason, this article will walk you through the process of obtaining the address through the router's web interface. Other methods may be used instead -- such as Windows Vista's Network Map or a third party utility. (The MAC address is also printed on a sticker on the bottom of most routers, but if the router is hidden behind a computer desk or trapped in a tangle of wires, using the web interface will probably be easier.)
First, open a web browser window and type in your router's local IP address (typically, 192.168.1.1) and hit Enter. When prompted, type in your username and password to gain access to the router's interface.
Once you've logged in, the blue and black Linksys page will appear. Click on the Status tab (the last one on the right).
The MAC address is assigned to the network interface port inside the router, not to the actual router as a unit, so since the WRT54GS has two network interface ports (one for your local area network and one for access outside your network) it will therefore have two MAC addresses.
The MAC address for the port that connects to the wide area network or to your Internet service provider can be found under the Router heading beneath the Status tab. It will be listed below Firmware Version and Current Time, and it will appear as six pairs of letters and numbers separated by colons.
The other MAC address, the one for the local port, can be found under the Local Network heading, and it will be the first item listed there. Typically these two addresses will be very similar -- maybe separated by one or two digits.
on Sep 28, 2010 | Linksys Wireless-G WRT54GS Router...
I can't get my new Nintendo Wii to access myr router
According to Nintendo web site, it happen because of firewall on the router.
You will need to disable to firewall on the router.
Open the set up page of the router. Disable the firewall. You will see it under security tab.
Reduce the MTU to 1365.
Also you can open some ports for the WII.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54GS Router...
Not getting in to the enter net.
Make sure your cable/DSL cable from your wall outlet is plugged into the "Internet" port on your router, and a cable from one of the 4-ports is plugged into the network card on your PC. Then, open your browser and type in the IP address of the router (default is 192.168.1.1). The Linksys menu should appear, and you can begin to configure it from there.
Feb 22, 2010 | Linksys Wireless-G WRT54GS Router...
1 linksys wrt54gs router 2 xbox 360's and a not open nat setting
connect the 360 to a port in the router and have the internet going straight into ur router ull stay connected at all times as soon as u turn on the xbox itll log on automaticly
Feb 21, 2009 | Linksys Wireless-G WRT54GS Router...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Trying to turn a Linksys WRT54GS into a hub
  1. If you want to set the router to work only as a switch with wireless access point, you may need to get into its setup page and adjust some settings.
  2. Using a computer that is wired directly to one of the router's Ethernet ports, launch IE and type 192.168.1.1. It is the default IP address of the router. Then it will open a window, asking for a username and password. By default, there is no username and the password is admin.
  3. Once you're in the router's User Interface, look for a sub tab called "Advanced Routing" under the main tab SETUP. Then set router mode to "Router" instead of Gateway. In some router's, the choice there is NAT enable or disable. If it is the one showing there instead of Router mode, then set NAT to disable. Click Save settings which is located at the bottom portion of the screen.
  4. Then click on "Basic Setup" and then disable DHCP server. Save the settings then.
  5. Then your modem now will be connected to one of the 4 Ethernet ports of the router.
Hope this helps!
Nov 21, 2008 | Linksys Wireless-G WRT54GS Router...
WRT54GS
what o/s are you useing?
Jan 12, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs cant connect..
hi try this before you hit the reset botton. Check if Windows XP firewall or 3rd party firewall are blocking the pings, and temporarily disable them just to be sure. The WRT54GS has a feature called "AP Isolation", It's on the "Wireless -> Advanced Settings" page. You won't need it for home use so turn it off as well. Last thing, do a firmware upgrade. Hope it's helps Good luck.
Mar 20, 2006 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
813 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
