Canon PowerShot A590 IS Digital Camera Logo
Posted on Dec 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Downloading pictures to my Toshiba computer (Vista)
I can't get "Direct Transfer" to show on my camera LCD. Nothing happens when I turn on the camera when it is plugged into the computer. I have installed the software that came with the camera.
  • Anonymous Feb 16, 2009
    ugh! i just bought a canon a590 on amazon because everyone said it's so easy to use. Um, that assumes that the software works right. I installed the software that came with the camera on my Toshiba that runs Windows Vista... says the camera cannot be found or recognized. So I installed the software on another computer (Dell, running Win 2000) and I am experiencing the same problem. I have no idea what the issue is but I basically can't upload anything to my computer at this point.
  • khakis May 25, 2009
    same problem
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Nov 04, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442580
Points
622693
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Mar 10, 2009
SOURCE: SOFTWARE NOT WORKING
You may know this already, but you don't need the camera to upload photos. I have used Nikon Digital SLRs for several years and have never uploaded from the camera. You should be able to do so, but in the mean time, remove the SD card and use a SD card reader. If your PC doesnt have a built in SD reader, get a USB version like the SanDisk MicroMate or get SD with a built-in USB plug(see attached photos for both. When connected to your PC, either will show up as a removeable drive on your PC from which you can copy the files onto your PC's harddrive: save the photos, back them up, then use the camera to format the SD card--this is the best way to clear/erase the card. Then try opening the photos with the Nikon software or photoshop or if they are jpegs, windows will view them. Using the camera to upload photos, in my opinion, should only be done when you do not have a way to read the SD card. This can be the begining of a productive workflow and part of the process for organizing and backing up photographs. You should also watch the Nikon website for software updates to fix bugs: http://support.nikontech.com/app/answers/detail/a_id/61 You should also check for firmware updates for your camera(1.11 is the latest for the D40 and no updates yet on the D40x): http://support.nikontech.com/app/answers/detail/a_id/13783
hgpilot
  • 82 Answers
  • Posted on Apr 29, 2009
SOURCE: pictures will not transfer off the camera
Here's a silly suggestion for you... is the "lock" engaged on your memory card? It will be a small sliding lock portion on the SD card. If yes, unlock it and try again.
Anonymous
  • Posted on Sep 22, 2009
SOURCE: driver download
perdi cd com programa da maquina
Anonymous
  • 9 Answers
  • Posted on Dec 10, 2009
SOURCE: I have all the softwares installed in my computer.
Find out where "Canon Camera Window" points to for its default pictures Folder and change that path or create a Folder in the location where it is pointing to ...
It seems to be directing the pictures to a non-existing Folder !
t00nz
CameraR
  • 4738 Answers
  • Posted on Jan 16, 2010
SOURCE: Cannot download pictures on new laptop with Windows Vista
If your camera is not relatively new and you're running Vista, Vista may have problems seeing it. Unfortunately, this can't be corrected as Canon did not update the drivers for Vista for many of its older cameras. But there exists a good, if not better alternative way to download your photos. Please don't take the following as a sales pitch as it's not, but please see this blog article, as it describes the use of an inexpensive USB card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
1helpful
Viewnx2 does not show any devices to transfer from
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
2helpful
When I plug cable from camera to USB computer connection, nothing happens!
Not enough information. The transferring of files requires a sequence of functions to happen before the pictures will transfer to the computer. You will need the camera software installed on the computer. The camera sequence for transfer and each camera is different, some just need you to turn the camera on after connecting the USB cable while others require you press the "Playback" button to transfer files. Depending on the camera software installed on a computer they "normally" download to a file folder then the pictures can be opened in the software programing.
Feb 08, 2011 • Cameras
1helpful
Connected Nikon L11 to Vista laptop. Picture Project software NOT installed. Turned on camera in hope Adobe Bridge could be used to transfer photos to laptop. Nothing happened and suddenly something...
Get a card reader. Use it from now on to transfer your pictures to the computer. Remove the card and battery from the camera...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Can't transfer pictures to computer
Found solution thru a google search, unplugged the camera from the computer, turned the camera off, plugged it back in and then turned it back on, the camera icon finally showed up in the Nikon transfer program
1helpful
Cannot download pictures from 4GB SDHC SanDisk Card
If your card reader is working, the card will show as a drive in "My Computer". Open the drive and you should see your photos.
On your desk-top, right click and select "New" then "folder" and name it "Camera Photos".
Select the photos you want to transfer from the camera card, select "file" from the windows toolbar, then "cut".
Open your new desktop folder and select "file" again from the toolbar, then, "paste".
Your photos should transfer in a minute or so.
Jul 03, 2009 • Cameras
3helpful
Cannot download pictures from camera to computer
What system Are You Using? Im Using windows Seven And Vista, It Will Not Work . Just Use Sd card Reader Or Flash Usb Sd reader.
Cant take a picture although camera turns on
2 possible solutions. !. try using another SD card. if the one in the camera is full, you cannot take a picture. 2. Try another SD card for transferring, (and taking pictures) and try transfer of this card in another camera or reader, such as the one in photo print places.
Gateway DC-T50...can't view or transfer images to my computer
how do i transfer pictures from my camera to my computor which has as its operating pro. vista?
Connecting problem
The easiest way to transfer images is to put the media card into a card reader attached to your computer.
Photos have horizontal lines
Ok, first of all......when you transfer the pictures to a computer are the blue lines still in the picture? Also if you reset the camera does the image still come out white?
A lot of times what happens is that there is nothing wrong with the actual picture it is the lcd. When you transfer the picture it looks ok you are only seeing the blue lines on the lcd. That means that the lcd is going out. If you transfer the picture and the blue lines are still in the picture after transfer then we can try to reset the camera as there is something else going on besides the lcd. More that likely it is just an lcd that needs to be replaced.
With a white image that usually means that the white balance is off on the camera. I would recommend resetting the camera and then try retaking some pictures to see if they are still coming out white. If they are then you would have to send the camera in to be repaired.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
