There are horizontal lines running across top inch of the screen all the way from one side to the other. TV still watchable and works fine but am wondering if this is an easy fix. Only paid $200 for the set and don't want to pay more than $100 to repair.
Thanks for your help.
David in VA
Comment by jacobson98, posted on May 06, 2007
Thanks
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 13, 2008
I have the same problem on my 2005 Toshiba 27AF45C the lines seem to spread farther down the screen from the top this is fricken B&(%$#*^T why is there no recall
Comment by Guest, posted on Jan 02, 2008
Cactus,
I have the same problem with the 21" screen. My tube is about 3 yrs old now. Can you amplify on your solution a bit. What does it mean to dry out a capaciter? Could I do that without a service call. Is that capacitor on a plugin board or does it have to be soldered into the circuits. Do you suppose I could order the parts from the Toshiba folks and repair it myself? Is there some sort of repair manual on the web (like a pdf) where I could figure out where that is?
Poowyll
Comment by POCKA, posted on Nov 30, 2007
I HAVE A TOSHIBA 27A43 TV WITH THE SAME HORIZONTAL LINES ACROSS THE TOP OF SCREEN-THIS SEEMS TO BE A BIG PROBLEM WITH THIS MODEL OF TOSHIBA-ANY RECALL NOTICES??
refer to qualified ,
regards ,
plz don't forget to rate
thx
Comment by sonysonyman, posted on May 07, 2007
i am sorry to see you givin me Average rate while i help you and gave you the perfect solution ,
you asked for help and i did and it is of course a matter of a repair man
pleased try to change your rate if my solution helps
regards
Was this solution helpful? Show your Appreciation by rating it:
But buying another Toshiba is going to be out of the question.
Have another tv, Sanyo and never had a problem and it is over 10 yrs old.
Come on Toshiba, when there is a widespread problem like this it should be recalled.
Post a New problem for Toshiba 27A44 27" TV
Email this problem
Can you Help with these Standard Televisions problems?
Can't get TV picture after...
