Question about Corsair Memory 2GB PC6400 DDR2 Desktop Memory
I have 4 sticks of memory that are Corsair XMS 2x1024, (2GB) and I have already got 2 installed. My question is I have installed the other two and now have 4 sticks. The LED lights are working, but the WinXP username screen when trying to log in, restarts the computer. any suggestions..
  • Anonymous Dec 30, 2008
    okay! I have taken out the 2 new sticks and works like a champ. When the 2 new sticks go in, no access.. so, not sure if it is the log in winlogon.exe file? My MOBO is dual channel and supports up to 8GB. confused? I should have no problem with installing 2 new sticks of the Manuf., the exact same models, (memory)
  • 149 Answers
Winlogon.exe has become corrupted....shouldn't be memory related.....try using safe mode to restore your pc from a restore point....alternativly you'll need a boot disk like ERD commander to boot from cd and get to a restore point
Posted on Dec 30, 2008
Using Corsair XMS Memory 2 1g sticks and works good, tried putting 2 more memory modules to upgrade to 4g and goes into a post loop??
The memory should all match each other (same type). That board should handle up to 16gb using DDR2 1066/800/667 modules, although Win XP can only go to 3Gb.
Apr 27, 2010 | Gigabyte GA-EP45-UD3L Motherboard
How do I install a memory card?
hi this is quite simple to do, open your case, locate the memory that is already installed, on either side of the memory stick there are 2 leaver looking items, push them downwards till they click, as you do this the memory stick will rise slightly, once both leavers are pushed down fully you can then remove the memory stick, keeping an eye on the location of the cut out in which way the stick came out, then position your new one in the same way and push it home, the 2 leavers will then raise up and click to lock the new memory stick in place, and then just replace the side cover of your pc and you are done...hope this helps
Feb 23, 2010 | Corsair Memory 2GB PC6400 DDR2 Desktop...
I can not get ddr2 to operate in slot 1 and 2. but will work in 3 & 4 . This is stopping me fitting 4gb of ddr2.Computer fails to boot if i use slot 1 & 2 Mother board is Gigabyte GA M55s3G...
Is this a brand-new motherboard, still replacable under warranty,
or a "well-worn" motherboard, with one or more capacitors that are either bulging or leaking, when you visually take a close inspection of the motherboard?
Oct 10, 2009 | Gigabyte Computers & Internet
I don't know what happened with your chat session but I assume you fixed your problem.
Try out to help fine tune your system!
Apr 21, 2009 | Intel Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Ram install
1. bad memory
2. the motherboard doesnt support single sided and dual at the same time.
3. bios needs update
4. wrong slots for dualchannel?
Apr 05, 2008 | Intel Motherboard
Open Questions:
See all Corsair Memory 2GB PC6400 DDR2 Desktop Memory Questions
Corsair Memory 2GB PC6400 DDR2 Desktop Memory Logo
81 people viewed this question
Top Corsair Memory Computers & Internet Experts
David Payne
David Payne
Are you a Corsair Memory Computer and Internet Expert? Answer questions, earn points and help others
