Question about Logitech Cordless Desktop EX110
Just installed EX 110 Cordless Keyboard and Mouse
Everything seems to be working fine other than the first row of numbers on my 10-key.
The 1, 4 & 7 aren't working, is there something I can do? Thanks
    President:
  • 2,692 Answers
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
Have cordless keyboard EX-100. Keys will not respond. The calculator and mute keys works all other do not. Have fresh batteries and reset connection button many times. My cordless mouse is okay.
You either need to push fn button (upper left on keyboard) or you need to check that the logitech keyboard software (itouch and a few other names i can;t recal) is running or installed. On mine if the software has glitched out, a quick reload of it and it works fine. This software is what is telling your computer what the special keys mean. If this isn;t running it will only be able to understand the standard type of key signals.
Sep 23, 2010 | Logitech Wireless Access Duo Optical...
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
My cordless mouse does not work the keyboard works fine
THEY NEED LINKING TOGETHER. YOU NEED TO REINSTALL THEM BOTH.
Mar 19, 2009 | Logitech Cordless Desktop EX110
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
Logitech ex 100 mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 22, 2009 | Logitech Cordless EX 100 Mouse
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Logitech Cordless Desktop EX110 Logo
81 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
