Question about Sansui CDVD9000
TV/DVD COMBO WON,T WORK ON DC WILL WORK ON AC
SET OPERATES FINE IN AC MODE BUT WILL NOT WORK IN DC MODE AND I DON'T HAVE ACCESS TO A SERVICE MANUAL FOR THIS BRAND/MODEL
  • richh0130 Jan 06, 2009
    Yes the dc fuse is good also the pico fuse on the pc board is good.I also checked all the diodes & voltage regulators but nothing shows as a definite open or short.Any other help you can give me would be greatly appreciated. Thanks BobYa.
    Rich (R.J.)
  • Sansui Master
  • 520 Answers
Have you checked the fuse in the plug on the end of the DC power cord? Just unscrew the end.
Posted on Dec 31, 2008
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
DC powered fine. AC Power intermittent
in order to find the connection, you will have to open up the tv carefully and follow the power supply in and probably a thin piece of metal will be broken and need to be resoldered back on. The broken piece will most likely be on or around the board.
Be careful when working on this because you could receive an electrical shock especially if you don't know what you are doing.
I would suggest letting the tv discharge overnight by unplugging it.
Please let me know if you need any further help or have any questions.
Thank you and good luck
Apr 14, 2008 | Emerson EWC0903 9 in. TV/VCR Combo
Tip
Toshiba 23HLV84 Service Manual Download
Download Toshiba 23HLV84 LCD TV / DVD Service Manual
Have you misplaced your Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
on May 03, 2010 | Toshiba 23HLV84 23 in. TV/DVD Combo
Hi will work on gas will not work on 110
This refrigerator is equipped with a control system, which can automatically select the most suitable energy source which is available, either 120 Volt AC or LP gas operation. The refrigerator can be operated in either the AUTO mode (thermostat factory preset below the safe food storage temperature) or MANUAL mode (continuous operation - no thermostat control).
NOTE: Under certain cool weather conditions, the food in the lower portion of the fresh food compartment may freeze if operated for an extended period of time on the MANUAL mode.
A. A 12 volt DC supply must be available for the electronic control to function. The refrigerator will work down to 9.6 volt DC.
B. Press the main power ON/OFF button (1) to the DOWN position.
B. In AUTO mode operation, the temperature is controlled by a single temperature setting, on the energy source selected by the control system. (See Auto Mode)
C. In MANUAL mode operation, the refrigerator will run continuously on the energy source selected by the control system. (See Manual Mode)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Dometic RM2652 Refrigerator
Tv runs on 110 but not 12volt
There is a fuse on the DC power line for AC/DC sets and you can start by making sure it isn't blown. The fuse may be in the cigarette lighter plug itself, or inside the TV. If you find the fuse blown, replace it with one of the same value and try it again. The fuses sometimes do go for no good reason. If there is some internal trouble with the TV, the fuse will go again and you'll know for sure.
Nov 30, 2008 | Supersonic FC2245 13 Color TV/DVD Combo...
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Toshiba 9" TV/VCR W/CAR AC/DC - No power when on battery
I would check on the inside for a disconnected wire or loose connection at the Dc imput if it still works on ac. You can most likely get a service manual at http://www.servicemanuals.net/ if the wires are intact on the DC imput and the jack itself fits secure to the adapter. Hope this helps
Oct 24, 2007 | Toshiba 9" TV/VCR W/CAR AC/DC COMBO...
TV in standby mode
Hi iducher the tv power supply is faulty have a tech repair your tv.good luck
Apr 26, 2007 | Supersonic SC-999TDVD 13 in. TV/DVD Combo
Emerson ewc0903
hi sorry only way for manual is through "sears" any way it looks like your battaries are dead! put new ones and see if it works good luck
Dec 17, 2005 | Emerson EWC0903 9 in. TV/VCR Combo
Sansui CDVD9000 Logo
100 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
