Question about RCA F27628 27" TV
Shrinking picture My TV will be on for a while (times vary) then it will "pop" and the picture will shrink from the top and from the bottom. There is something there, but you are unable to see it. Any suggestions?
  • Debbie dunlap May 03, 2007
    Not what I wanted to hear, but I appreciate the help. Is it cheaper to buy a new one or have it repaired? What is your recommendation, keeping in mind the new digital switch-over coming into effect.
    President:
  • 1,284 Answers
Your TV has sevral loose connections in the tuner circuit as this is a common issue with the chassis you have in it. It is not an issue for the novice to repair. You will need a technician to look at it.
Posted on May 03, 2007
  • Don
    Don May 03, 2007
    The current analog broadcast will cease in 2009. It will be heaper to replace the set than repair it since the cost are so much cheaper now.
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Latest version. DVD Shrink. Nero8 (Todays downloads) On two Laptops. Didn't have this problem with PC's.. Shrink working ok. Nero 8 Burning dvd's. Lap tops read /Play fine. Home dvd players to home TV...
try not to do anything or open other program while its dvd shrinking or burning....bcoz dvd shrinking and burning occupies lot of memory cache and cpu usage.
GOOD DAY
Sep 15, 2008 | Computers & Internet
TV screen shrinking from top to bottom.
My Dearest, j30;
It sounds like you have a problem in the 9 volt circuit which feeds the vertical output ciruit; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
This is not a repair that a novice should try, but if you call a factory authorized service center and have them come out and give you an estimate; AND tell them what the problem is, you will look know what you are talking about!
Aug 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Shrinking picture
I stopped by a local repair shop a got some helpful advise.
May 28, 2008 | Samsung TXL2791F 27" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Screen shrinking
You have bad solder connections on the vertical output IC or on one or more of the surrounding components. Good Luck
Jul 21, 2007 | Toshiba 36A40 36" TV
Shrinking screen
the tv is having a vertical problem have a tech look at it for possible repair.the problem is intermittent therefore it could be that it has cold solder or the vertical ic needs to be replaced along with spme caps that are not filtering the voltage properly,good luck.
Apr 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
RCA F27628 27" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
