Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
I have a LG TROMM washer.It is not washing properly.
I have a load of laundry but it is not washing, it stopped and on the minutes screen it says LE.What does LE stand for?
  • tammytam70 Jan 02, 2009
    The washer stops and gives me an LE error
    Scholar:
  • 140 Answers
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Posted on Dec 30, 2008
My lg tromm front load washer stops at 37 minutes
check the drainage pump or electronic board is faulty
Oct 20, 2014 | LG Tromm Front Load Washer And Dryer Set
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Where do i out the laundry detergent, when there are two sections
Look closer at drawer that comes out. The labels for pre-wash and wash are under the lip on my LG. Stand to the side and look towards your hand that opened the detergent drawer.
May 12, 2009 | LG WM2487H Front Load Washer
Keeps washing
If you are using a front load washer, never use more than one tablespoon of HE laundry soap per load. Now, to get rid of the suds you have: Get a package of Phyzeme (spelling?) tables for stomach gas. Cut about four of the capsules open and add the liquid contents to the washer, then resume wash. That will knock the suds right down without having to run about 10 rinse cycles through the washer.
Jan 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
316 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
