My laptop was not being used for an extended period of time; due too I need a power cord. Company was sending me the wrong one time after time. When I was able to finally get the correct power cord. I plug it in let it charge over night. When I turned on the next morning, it started humming. Does this have anything to do with the bios, I have noticed my date is incorrect and I found limited direction on how to change the date in the bios. May try later. Building up the nerve so to speak. This computer, have my entire client financial list although is backup, this laptop has been so reliable since I purchased it years ago. In addition, I have family pictures from the early 20th century, that new technology can't load these pictures. I am making one last upgrade on this computer. Then it will be strictly for pictures to pass down. Or until, the come out with a program to handle the earlier prints.
SOURCE: Toshiba Satellite A60 powers up then off after 2 seconds
Not yet. When I find the time I plan to try and switch out the power supply/jack in the back of the machine. I am hoping it is just a matter of a faulty connection. Thanks for asking.
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
SOURCE: Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
