Question about Microsoft Xbox 360 Console
Games will start up and load, but after a few min.
I can get any game to play, but after a few min. it goes back to the Xbox load disc main menu\sign in menu
    Problem Solver:
  • 7 Answers
May be your controller, have you tried to play with a different controller?
if this problem contenues to exist, call 1800-4MY-XBOX
Posted on Jan 01, 2009
Got the game in dec wont play got a second game and it wont load said disc unrecanisable
You chould check your disc, when you get that error, it means that the disc is unreadable, lol. Which means it cannot be read, so you can\'t play your game.
Check the back of the game disc for scratches or dust/other that shouldn\'t be there.
Jan 14, 2013 | Activision Nascar The Game: Inside Line...
Mass effect 3 wont start on my xbox
Hello,You should replace your disc. May be your disc might have some error. Contact the store where you purchased your game and ask them to offer you a replacement Gaming disc immediately.
Nov 11, 2017 | Microsoft Xbox 360 Elite Console - Black
Why does my new game freeze at the start menu on ps3?
It's freezing as it tries to connect to the EA servers.
If you want to play single player, sign out of the PSN before starting the game. If you want to play multi-player, at the moment it seems you can't, join the club :(
Quite a few people are having problems, not just on the PS3 http://forum.ea.com/eaforum/posts/list/330817.page
Nov 25, 2009 | EA - Electronic Arts Mercenaries 2: World...
My xbox is taking a while to load and doesnt read discs
when its loading just open your guide and sign in like that. Also if you have xbox live disconnect your cord
Nov 22, 2009 | Microsoft Xbox 360 Console
Any game i play disk arcade or demos xbox freezes
Try the following:
  1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
  2. Verify whether the Xbox console clock is set correctly.
    • Turn on the Xbox console without a disc in the drive.
    • Press the directional pad up or down to select Main Menu, and then press A.
    • Press the directional pad up or down to select Settings, and then press A.
    • Press the directional pad up or down to select Clock, and then press A.
    You can see the date and time from this screen. Correct the date and time as neccessary.
  3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
    1. Insert a memory unit into a controller connected to your Xbox console.
    2. Open the disc tray and remove any disc, if present.
    3. Close the disc tray and re-start your Xbox console.
    4. Select Memory from the main Xbox Dashboard, and then press the A button.
    5. Select Xbox Hard Disk, and then press the A button.
    6. Locate and select the game you want to back up in the list of games.
    7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
    8. Press the A button to display the Copy/Delete menu for the save game.
      Note: If Copy is not available, you have not chosen a save game file.
    9. Select Save, and then press the A button.
    10. Press the A button again to save to the appropriate memory unit.
    11. As soon as the copy is complete, press the B button to return to the list of save games.
    12. Repeat these steps as needed to back up your other saved games for this game.
    If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
    1. Open the disc tray and remove the any disk, if present.
    2. Close the disc tray and re-start your Xbox console.
    3. Select the Memory option from the Dashboard.
    4. Select the Xbox Hard Disk.
    5. Locate and select the game in the list of games.
  4. Select the large game icon to the left of the list and press the A button.
  5. Press the Abutton again to delete the game cache file.
    Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
  6. Select Yes to permanently delete the game cache, and then press the A button.
  7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
  8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
Sep 19, 2009 | Microsoft Xbox 360 Console
Arcade umplugged volume 1 wont play
i think iv had this one you put disc in then when its loaded goto arcade menu and i think the games are there rather then reading from disc
May 09, 2009 | Microsoft Arcade Unplugged Volume 1 for...
Won't read disc
sounds like the laser's stuffed. the lasers in those machines are notoriously bad. you'd best be careful. a dodgy laser will cause laser-burn to the discs. i had the same thing on my machine. i could play a couple of games, then there was some that would work after i took them out and put them in, several times. after fixing the laser, ive not had the problem again.
Mar 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 will play other games but not new one?!
try checking if ur discs scratched, as xbox 360s tend to scratch discs
Oct 04, 2008 | Microsoft Xbox 360 Console
Xbox console
have you tried setting Auto sign-in to off? It's in main menu->settings->auto sign-in
Nov 20, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
