Question about Sony Playstation 3 (PS3) Console
AV Cable Problems for PS3
My tv won't display the picture for my ps3. I have an AV cable and it worked before fine but it just suddenly stopped working. I tested the inputs on my tv and the dvd player worked fine. I also tested the AV cable with a volt meter and it was working fine.
  • 2 more comments
  • matthewmas Dec 31, 2008
    I switched my ps3 to a diffrent high def tv and i messed with video i think i put it on component on acident and the holding the power button didnt work help plz?
  • epicwin Jan 03, 2009
    Same problem here. I was running it on HDMI for the past few months but when i switched back to the A/V cables supplied with the console today, it appeared not to be working. A friend experienced the same issue as well.
  • Anonymous Apr 04, 2009
    I have tried resetting the system but the AV cable still doesn't work.
    When I use the HDMI cable, the system works fine.
    ANy other hints?
    Thanks
  • latnoflavr Jan 04, 2010
    I've got the same problem, but i was wondering if a "factory reset" will delete all saved data? I'm sure it would but i want to know if is has happened to anyone who has resetted their console.
    Thank you :)
  • 7 Answers
I am not completely sure that this will help you, however try doing a "factory reset".
You accomplish this by first (1) having the PS3 being off (2) hold down the power button on the front of the PS3. It will beep once when you turn it on and then a second time. When you hear it the second time, let go. See what happens.
Sometimes if you connect your consoles video a different way such as S-Video, Component or HDMI, your console remembers those settings and saves them causing many individuals to turn their console on and there is no video.
I hope this gives you somewhere to start.
Posted on Dec 30, 2008
  • l_garvin Jan 18, 2011
    I freaking love u man lol
Well this isnt a solution but thank you so much 1Mazin you seriously saved me. :P i was just about to get pissed and return this brand new ps3 but this fixed it. thank you. :)
Posted on Jan 07, 2009
Hold the power button until you hear 2 beeps, and then your problems should be fixed, the only thing that was reset was the back round wall paper, but they were still saved in the themes menu and none of the saved data will be reset
Posted on Dec 30, 2011
Oh my gosh my brother has an addiction for ps3 and when it wasnt working he flipped out so honestly this was a great help thank you sooo much!
Posted on Jul 17, 2010
Had same problem and this solved it!!! Thanks a million!!
Posted on Nov 20, 2009
It worked hooray
Posted on Dec 28, 2009
Thanx 1mazin your a genious
Posted on Apr 30, 2012
Wow, just tried this solution and it worked, thank you very much!
Posted on Jun 13, 2010
Thanx 1mazin
Posted on Feb 23, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: AV Cable Problems
try turning your tv on the input that you have the ps3 plugged in. Then with your ps3 on standby (the red light is on), hold the power button until the second beep. This resets the video settings
Posted on Dec 31, 2008
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
Av cable displays no video but only sound
Use your ps3 warranty and get Sony to replace that one with a new one.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
AV Cable Problems
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
No picture or sound
The PS3 works in some tvs only. Try connecting the HD cable in a tv and not the 3 Video and audio cable. Thats what happend to my PS3.
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
7,252 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
