The screen has horizontal coloured lines on the left half and is blank on the right half. The sound is still ok.
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
SOURCE: autiovox lcd Half the screen turns blue the other half has virtical lines in it.
Typical of the glue that holds the circuit to the screen coming loose.
it will take a very good repairman to fix this and he will have to know where to find the glue, its special with microbeads embedded.
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
SOURCE: Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
The lines are verticle not horizontal (don't know if that makes any difference!) It is a 27' Sanyo LCD and I just wanted to know a likely cause of the problem. Thanks.
