Question about Toshiba SD-4205 DVD Player
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray. Same problem. The only solution seems to be to take the player to a repair shop. My local Toshiba authorized repair service charges $85 an hour plus parts. The $30 estimate is applied to the total cost which would probably be over $100. Sadly, I don't think it's worth fixing given the prices on new non-Blu--ray DVD players.
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
marked
  • 6487 Answers
SOURCE: Toshiba SD-5000 DVD Player - disc tray stuck
Try first turning off the player and turn it back on and eject it using the eject button on the unit and also try to eject it using the remote.. IF still wont eject this can be a mechanical function on the ejecting part of the unit that you may need to open the unit and check for that..
Hope that helps.........
Posted on Aug 07, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
SOURCE: toshiba sd-310vu dvd player makes
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
Posted on Mar 13, 2009
  • 630 Answers
SOURCE: toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
Posted on Aug 30, 2009
Have a error on a nakamichi car stereo, e-mecha comes up when want to change a cd or eject a cd
Turning the radio off and back on or pressing reset clears the E-MECHA and the radio will again attempt to reach home.
For more details click the link below:--------
http://technoanswers.blogspot.com/2012/10/nakamichi-6-disc-in-dash-changer-stops.html
This will help.
Thanks.
Oct 06, 2012 | Cars & Trucks
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
DVD won't eject from Toshiba DVD player. I have already taken cover off and can manually engage the tray. When I try to eject with the remote I just get a little ''lock'' icon on my TV screen.
Press setup subtitle 3 audio 0 to unlock ...worked for me. Thank a user on Videohelp.com for solution:
http://www.videohelp.com/forum/archive/toshiba-sd-v295ku-locked-tray-solved-t362810.html
Nov 15, 2009 | Toshiba SD-V295
WANT EJECT
remove the top: inside under the disk carousel you will find a small locking pawl remove the disk carousel and you will see it pull gently on the carousel to locate it release the pawl and, the tray will slide right out (be sure to turn the carousel to the #1 position closest to the front before reassembling)
Apr 28, 2009 | RCA DRC8030N
Adding A DVD Player to an existing Digital TV box
You should connect the changer to the tv, not the digital box. It will still get the signal.
Apr 11, 2009 | Toshiba SD-3980 DVD Player
CD changer eject button does not work. Three discs are inside. Changer works. Good sound is produced. But unable to eject disc changer to change discs.
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Oct 27, 2008 | Curtis RCD-897 CD Shelf System
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
Mecha error
I had the same problem. My unit would not eject CDs. I was able to fix it by hitting the reset button. That restarted the whole unit and reset all the settings as well, but now I'm not having any issues with ejecting CDs.
Oct 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Mecha error
Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
Feb 03, 2007 | Kenwood KVT-717DVD Car DVD Player
Toshiba SD-4205 DVD Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
