Question about Compaq Computers & Internet
Desktop shutdown. will not come back on. Green light flashing.
Desh top shut itself down overnight to reboot and download. The power will not come back on. A green light in the back is flashing consistently green. Compaq Presario SR1318NX
    Problem Solver:
  • 12 Answers
This sounds like it might be a power supply problem. If you are tech savvy enough you can do this. 1st try unplugging it, let all the lights go out and then plug it back in. Try to turn it on. It might work. If not, unplug the pc and hit the power button to discharge all voltages. Open the side panel and watch where all the cables go. Label if needed. Unplug all cables carefully. The ones on the motherboard have a clasp that holds them. You simply sqweeze the clasp and it should pull free. After all cords are removed, remove the screws from that hold the power supply itself in. These are usually on the back. Pull the power supply out carefully. Take the unit to your local computer store. They should have a tester to test a make sure that it works ok. Replace if necessary. If it is not the power supply you might try only plugging in the motherboard and HDD. Remove and boards using a static strap between you and a grounded (plain metal) on the case. after that, plug the unit in and see if it powers up. If it doesn't, it could be the motherboard or a video board you needed to keep plugged in.
Posted on Dec 30, 2008
    Scholar:
  • 172 Answers
Clarify please:
can you hear the hard drive running ? see the cpu cooling fan spinning ? operate the cd/dvd drives, see nothing on screen though.... yellow standby light not the solid green light.
compdoctor2005@btinternet.com
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Tip
Create One-Click Shutdown and Reboot Shortcuts:
First, create a shortcut on your desktop by right-clicking on the desktop, choosing New, and then choosing Shortcut. The Create Shortcut Wizard appears. In the box asking for the location of the shortcut, type shutdown. After you create the shortcut, double-clicking on it will shut down your PC.
But you can do much more with a shutdown shortcut than merely shut down your PC. You can add any combination of several switches to do extra duty, like this:
shutdown -r -t 01 -c "Rebooting your PC" Double-clicking on that shortcut will reboot your PC after a one-second delay and display the message "Rebooting your PC." The shutdown command includes a variety of switches you can use to customize it. Table 1-3 lists all of them and describes their use.
I use this technique to create two shutdown shortcuts on my desktop—one for turning off my PC, and one for rebooting. Here are the ones I use:
shutdown -s -t 03 -c "Bye Bye m8!" shutdown -r -t 03 -c "Ill be back m8 ;)!"
Switch What it does
-s Shuts down the PC.
-l Logs off the current user.
-t nn Indicates the duration of delay, in seconds, before performing the action.
-c "messagetext" Displays a message in the System Shutdown window. A maximum of 127 characters can be used. The message must be enclosed in quotation marks.
-f Forces any running applications to shut down.
-r Reboots the PC.
on Jun 24, 2010 | Computers & Internet
Flashing red power light on Gateway 700X
try disconnecting the lower optical drive and rebooting...may just be a bad drive.
Sep 04, 2012 | Gateway 700 X PC Desktop
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
No power
This suggestion is a real long shot but at least it something you can try. It sounds like you've already ruled out all the other stuff I was going to suggest. Try replacing the CMOS battery on the mother board. It's one of those large flat batteries about the size of a nickel.
Jun 03, 2009 | Gateway 505GR PC Desktop
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Tv cycling on and off
Phillip you have a problem in the main power supply or in the High voltage shutdown circuit. Now the longer you wait to have this fixed the more its gonna cost ya Unless your a tech then get a schematic and measure the voltage on the hv shutdown pin on the video junglke ic when the set shuts down If the voltage at the time of the shutdown sodent spike up then you know your problem is in the power supply. Good luck
May 27, 2006 | Sony Grand WEGA KDF-50WE655 50" Rear...
Computers & Internet Logo
482 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
