Question about Diamond Audio D5-1200.1 Car Audio Amplifier
Diamond Audio Amp 1200.1 D5 Blows Fuses When Connected to Power!
I just got a used Diamond audio 1200.1 to power my Diamond D6s. I had the system working for about 3 weeks and it was the loudest system I've ever heard. One day, I disconnected it to test my other amp and then re-connected the diamond and it blew the fuses instantly because I never disconnected my battery. Now I purchased new fuses to use and it automatically blows them when power is connected. I don't want to have to buy a new amp. What should I do? I already took it apart and can't see any visible problems. Any suggestions? Any suggestions? Anyone having same problem with other amps? Anyone know where to get a new 1200.1 board to replace it? Please help!!!
  • timpotter Dec 08, 2008
    same thing
  • 113 Answers
If there was a misconnection polarity, you coud check fo shorted diode at power entrance circuit.
Posted on Aug 08, 2007
Whats the best way to hook up 2-10'' 4 ohm dual voice coil to the d5 1200.1 amp
4x4 ohm voice coils can be configured to either run @ 1 ohm, 4 ohm or 16 ohm, while the amp needs to be dropped to 2 ohms, no lower, to be most efficient. if a single dvc sup could handle 1200 watts, then hjust run 1, with both coils positive and negative inputs connected to the amps output. if you needed both subs, you would lilely only get 600 watts, by creating a 4 ohm load by running both speakers to the amp positive to 1 ccoil, each speaker, an mjumper cable between the negative of 1sdt clils to positive of 2nd coins, and running both 2nd coil negatives back from both speakers to the amp negative. the 2nd wscenerio will result in less sheer wattwage, but will also provide cleaner power. you need to study ohms law and parallel versus serial wiring to accomplish the 2nd scenerio, or, just get 2 4 ohm single voice coil speakers that can handle 600 watts apiece.
Sep 05, 2014 | Diamond Audio D5-1200.1 Car Audio...
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
May 24, 2014 | Definitive Audio Players & Recorders
Amp constantly blows fuses as soon as power wire is connected. anyway to fix?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you
May 22, 2011 | AudioBahn A2002T Car Audio Amplifier
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Power fuse on amplifier blows as soon as the power cable is connected
you should check the fuses your using may be too small and make sure you connect the positive first then the ground cable and there are no shorts when you ground the amp.
the most common will be the fuse ampage is too low thats why its blowing when you power the amp
Sep 18, 2009 | Pyle PLA600 Car Audio Amplifier
Mackie 1200/1400 blows all 4 10 amp fuses
missmatched impedance, insufficient ground, blown transistor.
Jul 20, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
Hooking up system to a factory infinity sound system in a jeep grand cherokee.
Tap into a signal wire (rear speaker wire) using a line level converter.
These convert the High level speaker wire output into low level RCA output that is accepted by your amplifier.
c5b61ef.jpg Get a good one Pacific Accessory Corporation (PAC) sni-35 is the best IMO.
The TRUNK-LOC is the SAME as the SNI-35 - but it incorporates a voltage sensing input - so you dont need to run an additional turn-on wire. The voltage is sensed through the speaker wire - and it turns on the amplifier.
Then you will need a fused power wire from the battery,
Ground to chassis, and remote turn on lead (if you use a standard line level adapter).
An amplifier installation kit will give you everything you need to add 1 amplifier (except the converter)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | Diamond Audio D5-1200.1 Car Audio...
Fuses blowing
It may not be your amp at all, disconnect the power wire from the amp and then try a new fuse. If it still blows you have the power wire grounding out somewhere, if it doesn't then it would have to be the amp.
Apr 01, 2009 | Diamond Audio D5-600.1 Car Audio Amplifier
Diamond Audio D5 1200.1 wont power up
you have a dead short on the board If your missing parts I myself would not bother to fix but if your up to a callenge contact www.diamondaudio.com they can assist you in getting the parts and diagrams for you
Mar 29, 2006 | Diamond Audio D5-1200.1 Car Audio...
Diamond Audio D5-1200.1 Car Audio Amplifier Logo
386 people viewed this question
Top Diamond Audio Car Audio & Video Experts
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
jeff5may32
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
