Question about Vivitar MAGNACAM Binocular
Poor quality Image quality is very poor. Binoculars are OK, but not well fit to the face. Photo of a bird was so bad it was impossible to identify the image, although the binocular view was reasonable. The 10 power size is a bit too much for these small binoculars and 7 power would be more reasonable. Overall this camera/binocular is not worth owning. Help! I have a Vivitar Digital 10/25 Camera Binocular (not listed as a Magnacam). I've tried all possible variables using the operation manual and can't get a decent picture to come out. This was a Christmas gift and I'm unable to return it to a store. I would not buy it if I were looking to do so as I can't figure out how to get a decent picture. I was so looking forward to using it when we got it for Christmas...it's just what we needed...I'm very disappointed with this item. Would love some help with this issue!!!
  • Anonymous Dec 30, 2008
    Hi too am very dissappointed with these binos. One thing that I found today is that the camera does not capture the image for several seconds after the button is pushed so it needs to be held on the subject for this time lapse.
    Sniper:
  • 73 Answers
My response to these always makes me sad. There is no way of getting good picture. These camera binoculars are neither good cameras or binoculars. They do neither well. The camera is just attached to the binoculars. What you see through the binoculars is not what the camera sees. The binoculars magnification is not the same as the lens in the camera. It is like holding a camera on top of a pair of binoculars. The camera will take a picture in the area approximate to where you are looking. Digital cameras have a sensor. The more megapixels the larger the sensor should be. Camera makers are now making compact cameras with huge megapixel capacity without increasing the sensor size. The result is worse looking pictures. Not much is different with the cameras attached to binoculars only the sensors are much worse quality than those on a stand alone digital camera.
Maybe not the solution you wanted buts its the truth. If you do want to take bird photos your best bet is a pair of binoculars on a tripod with a digital camera adaptor and camera attached. The camera adaptors that are made in China are not expensive and are copies of some of the high priced units out there. all the adaptor is is a bracket which attaches to a tripod which holds the camera to one of the binocular lenses. That way you see what the camera sees through the binoculars.
Posted on Aug 02, 2009
Poor picture quality have tried resetting factory settings also have taken photo of picture so you can see what I mean but don't know how to send this to you.
Poor picture quality can mean different things - could you be a little more specific, please ? For example is it over or under exposed ? Out of focus ? Suffering from camera shake or subject movement ? Electronic noise degrading the image definition ?
Jul 17, 2016 | Cameras
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Keyocera km 2560 poor quality copy but good quality report print
dear clean the platen glass and its cover. adjust the sharpness.darkness.image quality to text and photo.
your printer is in good condition.
thanks.
Mar 30, 2015 | Office Equipment & Supplies
Poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Webcam
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Feb 28, 2008 | Logitech Webcam
Poor print image
You use your printer settings to set quality of image.
Jan 31, 2008 | HP Photosmart D7160 InkJet Printer
Vivitar MAGNACAM Binocular Logo
322 people viewed this question
Top Vivitar Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
