Question about Power Acoustik PMD-100NT Car Video Player
Disc won't load
Everytime I load the disc in the player you hear the disc loadin but it does not play. It just keeps making the loading sound "drrrrrrrrrrt drrrrrrrt drrrrt" This goes on for about 10 min. before it spits back out the disc. Even if you press eject the disc doesn't come out. Press play it doesn't respond. Discs are clean and play in other dvd players. Help!!!!! Its no fun listening to toddlers aks why no thomas overr and overr again.
  • 1 more comment
  • UtahDad Nov 06, 2007
    We have the same issue. I am eager to find out if the solution presented works, but am leary of taking apart the DVD player unless I have more specific instructions. Can you describe the repair using more detailed steps from beginning to end? I imagine you start by unscrewing the casing, but what do you see when you pull it off?
    I'll check back in once I've tried to remove the case, but I'm considering buying a low-cost external drive and plugging it in.
  • salrandazzo Aug 21, 2008
    DVD's won't load
  • Anonymous Mar 24, 2014
    When we load ANY DVD in the player, we get a "loading" message, but the system does not fully engage the disc. It goes in, but the mechanism that loads the dvd won't lower so that the dvd can be read. Then it ejects the dvd after about 5-10 seconds.
Their are two possible causes for this problem, 1- the flat white  cable that connects dvd player is not making contact where it conncts to dvd player. 2- the dvd laser eye is binding on the plastic trck that it slides on. This is a fairly simple fix remove track and use a razor blade to gently scrape the track in the spot it is binding, you can determine the spot by manually rollin the hesad back and forth.
Posted on Nov 01, 2007
Hi, I had the same problem with my PMD-100NT. I found that there was a motor inside that, I think, was moving the laser head was skipping and the head was not moving into position. I hooked a portable to the external jacks and I am just using it as a monitor. I am quietseas4john@yahoo.com if you have any questions.
Posted on Aug 21, 2007
I nede to install the power acoustik on gmc envoy 2004 the system is bose tanks
Posted on Mar 09, 2008
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Jul 04, 2010 | Panasonic DMP-BD30K Blu-Ray Player
Disc does not appear to load. When inserted in
If you have a disk that you know works, try it. Make sure the disk is not upside down.
Dec 29, 2009 | Polaroid PDV-0823A Portable DVD Player
Dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Mar 14, 2009 | Samsung DVD-V3500 DVD Player/VCR
Player won't read cd's keeps opening door
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Oct 25, 2008 | Yamaha CDC-565 5-Disc CD Changer
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Loading but not playing
Try a firmware update
Feb 07, 2018 | Jwin JD-VD136
Power Acoustik PMD-100NT Car Video Player Logo
530 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
