Question about Sony SLV-N55 VHS VCR
VCR with intermittant audio and video problems
I have a Sony slv-n55 VCR with intermittant video and audio problems. It has a built-in tuner; the cable comes into the house, into the VCR, and then from the VCR output on the VCR into the TV set so I can watch one program and record another at the same time. There is no external "box" involved.
The TV also has its own tuner. Until a few months ago, everything was working perfectly. No problems with picture or audio even when I was watching a different channel on the TV while the VCR was recording a different channel.
Now I've started having audio and video problems with certain channels (mostly local channels, for some reason) with all others ok, even if I'm watching one channel and recording another. Hookups are tight, and no settings have been changed.
All things being equal: 1. My cable connection is from Mediacom Cable. Could my problems have anything to do with the signal I'm receiving from the cable company during the run-up to digital conversion? I know it shouldn't, but you never know. 2. Is it possible for the built-in tuner in my VCR to fail selectively and affect some channels and not others?
    Problem Solver:
  • 11 Answers
You have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Posted on Dec 30, 2008
VHS Stuck; Cover is off; nothing moves...wheels, tape...nothing...help
Unplug the unit, then plug it back in WHILE holding down the EJECT button ... The tape should come out unless there is a belt broken, missing, or loose.
I have used old, inoperable VCR's for tuners only as well. What happens if you leave the tape in all the time? Does the tuner work like that?
May 16, 2017 | Televison & Video
How do I get my VCR to tape programs
Two things to check here. Lets verify the basic functioning of the unit. Have you tried playing back a pre-recorded tape? If so, please post the results here. I suspect that a pre-recorded tape will fail as well. If so, I'll post instructions on how to resolve the problem.
Please keep me posted.
Thanks,
Dan
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Sony SLV-640HF Problem
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Dec 26, 2008 | Sony SLV-N55 VHS VCR
No Problems with my SLV-N55 except for one
This remote is still available from any Sony disatributor. It can be found using part number: 147728211 from Tritronicsinc.com for $38.95 plus shipping.
Dan
Aug 08, 2008 | Sony SLV-N55 VHS VCR
No sound on vcr
hi papalon5,there seem to be a problem with your cables.check if u have connected it properly i.e the red with the red adapter n so on..
Apr 28, 2008 | Sony SLV-N55 VHS VCR
Intermittent tuner operation
have you tried to move the switch to channel 4 on the back of the vcr ( you will have to watch the vcr on channel 4)
Jan 28, 2008 | Sony SLV-998HF VHS VCR
Sony SLV N80
DId you open up the VCR and take the quarters out?
Dec 05, 2007 | Sony SLV-N55 VHS VCR
Video signal into VCR
you have to select to switch from comopsit to s-vhs for the video input in your sony slv -n55 to get the video reached to it regards please don't forget to rate ,thx
Oct 15, 2006 | Sony SLV-N55 VHS VCR
Sony SLV-N55 VHS VCR Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
