Question about Fujitsu M4099D/FI-4990C Scanners
Fi4990C fi 4990c keep getting this reading on my scanner when I put paper to be scanned of my stacker it picks up the first sheet than this comes out "Frontside background changeover function overrun".
  • 31 Answers
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Posted on Jun 10, 2009
4 Suggested Answers
SOURCE: Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Posted on Aug 10, 2007
SOURCE: Background changeover unit failure on 6130dj
Background changeover unit failure [fi-5120Cdj #2 , 048005 , c2]
Posted on Aug 18, 2010
TechSatya
  • 104 Answers
Hi Vivek,
Thank you for contacting Fixya.
When a background switching malfunction occurs, "E" and "F" will display alternately on the function number display panel of the scanner.
Background changeover unit failure error is detected in initial checking at power on. Probable causes:
- Insulation material damage of BW motor cable or the damage of the wire in the motor. - Defective lamp or CCD or CCD cables. - CCD Connector disconnected. - Defective Control PCA.
Solution:
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 (or isopropyl alcohol) and check if the problem persists.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON. 2. Check if the cables between the Control PCA and the BW motor damaged? Are the connectors connected correctly? Check & confirm the position of the BW motor and check the cables. 3. Check Is the CCD cable F or B damaged? Or are the connectors connected correctly? 4. Check if the OPT Unit is installed correctly? 5. Check if the white reference works properly? If not, then replace the BW Motor. 6. If the above do not resolve your issue, then you may have to replace the Control PCA or Optical unit to see if the error is resolved.
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Posted on Aug 19, 2010
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Gray shades Everytime I scan a white sheet of
Try adjusting the contrast and brightness settings when you scan. If the contrast is set wrong it will pick up the shade of the white paper.
Sep 30, 2013 | Canon DR-3080CII Path-Through Flatbed...
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do you replace the feed roller on a fujitsu 4097 scanner
Hi Ranji,
The life span of the Pick roller is about 200,000 sheets or one year. Use Abrasion counter on the operator panel to estimate when the Pick rollers need replacement. The life span may be decreased by as much as half when carbonless sheets are frequently read. To replace Pick Rollers, please follow the steps provided below:
a. Remove Guide AASY. b. To remove the Pick rollers, turn the stopper counterclockwise. c. To remove the Pick roller 1, move the Pick roller 1 toward the left then lift it. d. Right after removing the Pick roller 1, remove the Pick roller 2 with the same way. e. To attach the new Pick rollers, place the Pick roller 1 from right above the groove for the Pick roller 1. Put the shaft of the Pick roller 1 into the groove. Then, slide the Pick roller 1 toward the right side. A Pick roller 1 has the groove in its rubber. Make sure that the bushing is securely fixed to the grooves. f. Attach the Pick roller 2, then slide the Pick roller 2 to the right. Make sure that the bushing is securely fixed to the grooves. g. Turn the stopper clockwise to secure the Pick rollers.
regards,
TechSatya
May 20, 2010 | Fujitsu M4099D/FI-4990C Scanners
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Scanner won't pick up colored inks from paper, multiple sheet jam
This printer only prints black and white. Canon do not supply Multi-color toner catridges for Canon Imagerunner 1023N
Jan 10, 2018 | Canon imageRUNNER 1023N Black and White...
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Double feed detection
though it has a flexible papr handling capabilities you might want to consider the ff:
Stacker Capacity: 100 Sheets Document Feed: Automatic or Manual Document Size: Width: 2.2" - 10.1"
Length: 2.8" - 14.3" Thickness: Automatic: 0.06 - 0.15mm
Manual: 0.06mm - 0.20mm Feed Capacity: 100 Sheets
all scanner are equipped with double feed prevention, however it still the user responsibility to ensure that you follow manufacturer's advice, to prevent double feeding:
1- do not feed dog eared paper
2- moistured paper or with strong humid
3- concave paper
4- convex paper
cheers!
Aug 28, 2008 | Canon DR-3080CII Path-Through Flatbed...
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
290 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
