Question about Oster 76076-040 Hair Trimmer
Where do i put the oil to oil the blades
Trying to oil the blade and not sure where to put the oil
    Problem Solver:
  • 13 Answers
When oiling clippers you want to have them running and tilted blade down toward the floor. You put about 3 small drops right on the running blades. Then wipe off excess oil with a towel. You dont want the oil running back into the motor of the clipper. You should oil them about every other use. Good Luck!
Posted on Jan 10, 2009
3 Suggested Answers
  • 40 Answers
SOURCE: Hair stuck between blades...repeatedly
They are garbage.....it's a common problem. Call the manufacturer
Posted on Aug 04, 2009
SOURCE: My Oster Golden sounds great until I put two of
sounds like the blade sockets may have bent or cracked, the ears will spread wider alowing the blade to rattle on the clipper.
Posted on Jan 29, 2011
The motor will hum when you put the paper to the blades but it will not shredd because the blades do not turn.
Blades need to be cleaned and oiled Unplug and check to make sure there are no staples or something caught in the gear edge in the corners You should be able to turn it by hand If not the gears inside probably slipped out of place or got busted from somebody trying to shred too much at once
Apr 24, 2014 | Royal 160MX Shredder
Need to know how to get the blade off the miter saw to replace the blade
First, make sure it's unplugged.
On many saws the guard mechanism partially covers the bolt that holds the blade in place. Loosen and move the part out of the way as recommended by the manufacturer. On this saw you loosen a screw and then slide the mechanism up and towards the rear.
Press the spindle lock to lock the blade in place. Turn the bolt clockwise - opposite the normal direction - to loosen and remove it. Remove the outer blade washer and the blade. Leave the inner blade washer in place. Wipe a drop of oil on the surfaces of the blade washers that touch the blade.
Put the blade on the saw so that the teeth point down. Putting the blade on with the teeth facing in the other direction can result in serious injury. Put the outer blade washer in place. Turn the bolt counterclockwise until it is snug, plus another 1/8 to 1/4 turn. Replace the cover and you're finished.
Oct 27, 2011 | Saws
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Feb 12, 2010 | Garden
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
Aug 01, 2009 | Andis 01690 Hair Trimmer
How to repair my hair trimmers?
I am a retired hairdresser and it sounds like one of three things or a combination. Your blades may be worn (dull) and need replacement , it may need to be oiled,the blades could be "misaligned" and need to be adjusted. You do that by removing the two screws holding the blades on, remove the blades, while you have them off, clean out any built up clippings in there and then put the blades back on. BEFORE you tighten down the screws make sure the "teeth" from the blades are lined up so the bottom blade teeth can be seen BETWEEN each top blade tooth. NOT directly on top of each other. Now tighten the screws. urn the clipper on and add a drop of clipper oil (no substitutes) onto the running blades. That should do the trick.
Jul 20, 2009 | Andis Outliner® II 04603 Hair Trimmer
Oster Golden A5 Clippers
try running the blade for a bit keep lubricating in between the blades its important to oil your blades during and after use to avoid rust build up on the cutting surfaces. Also just make sure the blade is engaging onto the clippers ok.
Sep 28, 2008 | Health & Beauty
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-040 Hair Trimmer Logo
252 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
