Question about Microsoft Office Professional 2007 Full Version for PC
How to test if DVD rom and DVDrw drives are functioning properly
At present I am not able to burn copies of my CDs
  • HVA5976 Jan 07, 2009
    Roxio enabled me to burn copies from Drive E (dvd/cd) to Drive F (dvdrw/cdr). Now I noticed that it doesn't. I probably downloaded something that I shouldn't have.
    President:
  • 2,692 Answers
Place a readable disk cd disk into the cd . Go into MY COMPUTER and see if it is there and if you can open it to see the content.
Put a blank CD into the dribve.  Open     MY COMPUTER , open CD DRAG something into the CD. see if it wil transfer and burn. It wil say "programs ready to burn"
DVD unless it is a Data DVD you have to have  softweware for the DVD player and Burner not supplied by the windows System.
Posted on Jan 05, 2009
It really works. Thank you very much for your information.
Forex
Posted on Jul 17, 2010
I wish to check my dvd-rom data disctime using my pc,but how?do i need to install any supporting software?
Posted on May 24, 2010
I want to know how to make copies of DVDs and audio CDs using acer aspire 5742 laptop
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
May 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
I have bought a Super slim external USB portable 24x CD-ROM for my Dell notebook. I can't get DVD's to play on it. The laptop recognises the removable device but there is no option to play the disc. Can...
CD ROM drive will play only 700 mb CD disks(normal CDs)...and not play DVD disks...u need DVD ROM drive to play DVDs....there is a big difference among both in it's function.
a DVD drive "may" play both DVDs and CDs....
but
a CD drive will "only" play CDs
Feb 18, 2010 | Computers & Internet
I have a dvd/cd SD-R6252 unit in my r3000 compaq presario. I've burned CDa but cannot burn a DVD. I think I know the answer but I want to be sure is this unit capable of burning DVDs?
Hi, well ur DVD\CDRW drive is a combo drive. It can play CDs\DVDs but burns only CDs as it's NOT a DVDrw @ the same time. It won't burn a DVD.
.... In future I propose u either to replace the drive by a DVDRW or u may buy an external slim dvdrw if u want to keep ur existing drive as well. 2nd solution is best BTW.
Feb 08, 2010 | Compaq Presario R3000 Notebook
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
CD-RW/DVD ROM Combo
no you want a dvdrw or dvd burner
combo only burns cd's and reads dvd's(not write/burn)
Jan 05, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Have problem with computer allowing me to copy to dvd-rw or cd-rw. I can play both, but can not copy to discs. I have windows xp professional version 2002 service pack 2
Please remember to always note Computer specifications and Operating system details when you post a problem and to explain your problem in more detail( Specify your CD-ROM / DVD Drive more)
If you cant burn DVDRW or CDRW it is likely that your Drive does not support burning these Formats. You can check on your drive at the front; it should tell you what it supports.
Another solution could be that you are not using the correct software to burn your DVDRW/CDRW. I recommend using: Nero
Kind Regards,
Stef
Apr 15, 2008 | Computers & Internet
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Nov 17, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Microsoft Office Professional 2007 Full Version for PC Logo
5,460 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
