Question about Freezers
Need newq thermostat
Where can I find a replacement thermostat for a International Harvester chest freezer model 15-FC
Found part locally
Posted on Jan 03, 2009
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Norfrost c6aew chest freezer compressor wiring
What is the make and model of this freezer?
Mar 14, 2013 | Freezers
Need diagram for thermostat for chest freezer
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire. HERE
If you have questions please let me know, Thanks Sea Breeze
Mar 08, 2013 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
Mar 02, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
My kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Nov 21, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I wolud like to modify my Kenmore chest freezer to -40F.
the amount of coolant is not the issue, its strictly a thermostat issue,WOW -40 though i dont know where youd geta thermo to go that low. def not in ANY residential/local appliance outlet
Mar 23, 2008 | Freezers
Freezers Logo
101 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
