Question about Dell OptiPlex GX270 Small Mini-Tower Desktop (162823025)
Dell GX270 Maxtor 7Y250M0
System is Dell GX270 with Phoenix BIOS A07 update. Problem 1st occured when trying to reload Windows XP. Install completed succesfully but after 1st reboot the primary serial IDE master hard drive SELF MONITORING SYSYETM reports that a parameter has exeeded its normal operating range. A parameter out of range may or may not indicate a potential hard drive problem. Press F1 to continue and F2 to run set up utility. If i press F1 systems boots normally into Windows XP, if I press F2 nthing lloks wrong in the BIOS setup and I do not see any options there to reset or clear the error in the self monitiring system. Ran test on NTFS and it is OK. Ran error checking on this disk in XP and all OK except for some bad blocks reported, otherwise the NTFS file system is sound. Ran drive diagnostics and dirve passed confidence test, drive self test, and SMART test, its had read failures on the bad blocks and verify tests for 768 blocks in the 28440867 to about 288463199 range, with error code 0F00:1A44 and 1error code 0F00:0244 on block 2882278115 Uncorrectable data error or media is write protected. Another quick drive tests simply breturns code 7. Other than the msg on boot up from the DRIVE SELF MONITORING SYSTEM, the systems appears to function normally when F1 is selected and boot continues to load WINDOWS XP. Anyone have any ideas how to get rid of this message, fixes, etc... ?
    Novelist:
  • 124 Answers
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Posted on Dec 30, 2008
Encountering the Error STOP 0x0000007B when Installing Windows XP on Optiplex gx270. Error occurs when Setup starts loading Windows Setup Files.
That error is a boot device error and you need to check the BIOS to see what is listed for hard drives and other devices and see if AHCI is enabled etc.
Oct 27, 2017 | The Computers & Internet
I am trying to upgrade to a 1tb SATA HDD on my Dell Optiplex GX270. It does not recognise my new drive in my BIOS, I have updated BIOS to A07. Am I missing something? Is it compatable with SATA?
I have the same model PC with a 250gig Sata HDD and dont have any problems. If a PC can read 250g it should be able to read 1000g. This may sound silly but is Sata turned on in Bios
Mar 25, 2011 | Dell OptiPlex™ GX270 PC Desktop
I have a Dell GX270 SFF - after plugging power cord in wall, the indicater light on front panel turns amber. The unit will not boot up unless I hold the power switch in, and wait for the light to go out....
You might check on the CMOS for your unit. Make sure you have the latest version... it sounds like your computer is starting up in sleep mode by what you have stated. This can be adjusted in the CMOS area for power savings. The issue might also be in Windows itself too if the computer boots far enough along when it turns ogange, as Win XP has some power savings features that can corrupt in the Registry. My first thought is the CMOS though. Yours might be adjusted incorrectly or might even be corrupted (there were some viruses about 3 years ago that would scramble the CMOS on various Dell machines that I know for sure was the 260 and 280s.. yours being a 270, makes me suspicious of this possibility. To be sure, I would flash it to the newest version anyway just to be safe. Dell.com under support is where it is at.. you are wanting the BIOS update.. (dell calls it BIOS). The newest version is "A07" from July of '06. I am not sure if this will work, but here is the link to Dell BIOS A07:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Thanks!
Stan Skaggs
Oct 19, 2009 | Dell Computers & Internet
Windows XP wont read DVDS and resolution sucks.
You will need to restore the original software installation. If your warranty is still in effect you will want to contact Dell for service, this is the best possible opportunity for a complete recovery and a happier outlook
Jul 26, 2009 | Dell (7W036) DVD+RW Burner
How do I make my MAXTOR Hard Drive 7Y250M0 a slave?
A slave drive is defined by removing the jumper (pin sleeve) completely from the drive. Then go into your BIOS and if it doesn't auto-detect as slave, manually change the settings and you'll be good. You shouldn't have to go into your BIOS.
If you can see it as slave in BIOS, but not in Windows that means the drive is not formatted properly and to do so, Right click on My Computer in Windows and goto Manage. It should load the Computer Management window. From there goto Disk Management under Storage in the left side browser. You should see the Hard Drive there, right click on that and format it.
That should do it.
Dec 12, 2008 | Maxtor 7Y250M0 250GB Serial ATA 7200rpm...
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Nov 17, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex gx270
Hi, reset the BIOS u need to follow below given steps(Perform all the steps carefully )
1.Restart the notebook.
2.Tap the F10 key as soon as the Dell logo appears.
3.Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes".
Gizmo1
Oct 14, 2007 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
1,675 people viewed this question
Alun Cox
