Question about Delphi Roady XT XM Radio Receiver
Whinning noise with my delphi roadyxt
Last year I received a roadyxt as a gift. I started using it in my 2002 Toyota highlander with a cassette adapter. A few months later the casstte player in my highlander started acting up so I bought a FM modulator. Now I get a whinning noise when I play the roady through my stereo. I do not believe it is an alternator whine as it happens even when the engine is not running. The whine only happens with the Roady if I connect my iPod to the modulator no whine. I am at a loss.
  • jdimare Jan 02, 2009
    Thanks, I will give it a try
    Top Expert:
  • Delphi Master
  • 77,499 Answers
U are picking up spurious radio noise (comes from anything that uses electricity and other things like overhead transmission lines, it may be from the cassette player motor, go to radio shack and try to find an RF filter that will suppress this noise, that should take care of it, also the chassis of the cass adapter must be grounded to the car chassis sheet metal, if not the motor noise can come through from the little DC motor's in the player.
Posted on Jan 01, 2009
Will delphi sa10000 without cassette player
Should be able to hear Sirius channels through your FM radio. Cassette is better, but you can just set up your FM radio to the same channel as you set the Delphi unit. See instruction manual (download from online here) http://www.siriusretail.com/pdf/hardware_support/delphi/skyfi_operations.pdf
Jun 01, 2014 | Delphi SKYFi SA10000 XM Radio Receiver
I have a 2002 toyota highlander with 231000 miles on it.How long will it last? still runes good!
regular oil changes and maintenance it's hard to say how long it will last. do those things and fix mechanical problems as they arise and it should outlast the body on the vehicle. i clocked over 400,000 km on my last vehicle which is close to the milage you have run up. it still ran ok and is likely still running. i only sold it as i picked up a vehicle with extremely low miles on it.
Nov 03, 2010 | 2002 Toyota Highlander
Toyota Highlander with loud humming noise
yes your right... it could be the wheel bearings, try replacing them.
Jul 27, 2009 | 2002 Toyota Camry
Intermittent rough idle on 2002 toyota highlander
before you do this I would get some wooden qtips - the long ones auto detailers use. take off the air filtrer assembly and spray carb cleaner into the air\fuel intake and use the qtip to wipe out the inside of the intake. I had the same problem with my highlander a year ago and this fixed the problem.
Mar 31, 2009 | 2003 Toyota Highlander
2002 highlander radio code
Good news: You do not have to worry about you issue.
Your radio (if it is a "factory" radio) does NOT require a security reset code. You do not have an "anti-theft" radio. You can disconnect the battery cables at will, and the only issue you will have is that you will lose the preset stations that you set manually.
The "anti-theft" radios were abandoned by Toyota several years ago. Hope this eases your mind.
Oct 14, 2008 | 2003 Toyota Highlander
Roady XT Problem
Sounds like a software glitch, you should try
I need to get my Delphi XM Roady, Roady2, or RoadyXT repaired, where can I take it?
At this time, Delphi does not currently have an authorized repair center. If you are within your one-year warranty period, please contact the Delphi Warranty Center at 1.877.GO.DELPHI (1.877.463.3574). Hope this is helpful
Mar 11, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
53 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
