Question about Canon CP-220 Thermal Photo Printer
Printer is only printing on the right side of the photo paper
Hi, my CP-220 photo printer is only printing on the right side of the photo paper. I have checked and double checked all the settings and everything seems fine. I have installed the last version of the drivers but the same thing continues to happen. Thanx in advance. Bye, Jorge
  • 13 more comments
  • Anonymous Nov 27, 2007
    printer prints on right side only.
  • galatron Dec 02, 2007
    I have two printers, a cp-220 and a cp-330, both show this problem during a major photo gig, WTF? why did this happen? both printers are transported in an extremely padded and secure case, and the printed fine a couple of days ago, I tried new print cartridges, this is really disenchanting.
  • daron73m Dec 21, 2007
    Yeah I am having same dam issue. Thought it was the old cartrige and just wastdd 30 bucks on new ones and still only prints half the page...Im done with canon products. Hardly have used this thing and have kept it stored in its box when not in use!!
  • dooter Mar 20, 2008
    I also have a Cannon cp-220 printer that has recently started only printing on the right side of the sheet. Has anyone had any providence with Cannon replacing the bad part?
  • nhns May 07, 2008
    Add another printer to the list with this problem...
  • jamonkko Jul 08, 2008
    I had exactly the same problem. The solution that is presented below (drop some glue) should help.
    I used non-liquid super glue and that didn't work. The plastic part still gave away when printing. Tip: don't attach the cover when you test printing after doing the fix with the glue, you will see if the plastic part doesn't hold and cracks apart. At least that happened to me. Now I will let the second glue layer to dry for one day before testing it again, I hope it holds then.
  • yodaseablue Aug 06, 2008
    I have the same problem with my CP-330. Can you explain exactly where I am supposed to put the super glue? Is it along the crack in the white part which wraps around the rod, or is it where the metal end touches the white "tab" part below? (The white part pivots around the rod, so that the tab moves up and down as it prints (or rather, as it doesn't print...))
  • jamonkko Sep 27, 2008
    Yodaseablue: the aim is to seal the white cracked plastic part tightly shut with the glue. So apply the glue and then press and hold it tightly shut. Also allow enough time for the glue to get attached. I waited 24 hours.
    If the white plastic part is fixed like that then the mechanism works.
    I didn't have very accurate tools so when I applied the glue it also leaked between the axis and plastic part, not just in the crack, but it didn't seem to cause any problems.
  • carmo5 Jan 10, 2009
    my printer Epson Stylus dx 8400 only prints on theleft side of paper
  • Ian59 Mar 15, 2009
    Our CP-220 only printed on half of paper. I followed the copper wire idea (no glue) and the printer works well. Thanks all for your help, I will now return the new HP photo printer to the shop for a refund.
  • kenza959 Mar 25, 2009
    Hi! I have the same problem. CP-330 has used maybe 4 cartridges, was stored in the original box for 4 months and the white plastic cracked. I will try to glue it now. Is there a way to buy that piece of plastic as a spare part? Thanks
  • Anonymous Apr 01, 2009
    Wow! This site was great! I too had the cracked plastic lever and used super glue to fix it. But now I can't remember how the left gear lever was orintated with the gear wheel. I have manually rotated the wheel so that the printer head is in the up position. So do I just leave the lever sitting obver the gear wheel or do I need to push it down so that it somehow connects the the wheel before I put it all back together? Thank you in advance.
  • Anonymous Apr 23, 2009
    was working great... then one day went to use it and it only prints one side of image - checked ink cartridge/ paper/ cleaned... no luck!
  • Peter Wong
    Peter Wong Dec 16, 2013
    galatron Thanks for the great solution. I used a soldering iron and melted the plastice together. And so far it works. ...what a crppy part they put in
  • KaSiris Xavier
    KaSiris Xavier Jul 31, 2014
    galatron thanks ... i used dental floss and glue, here's a video
Thanks galatron, you were right.
Here's a picture of the broken part (the white plastic part on the right).
Posted on Jan 26, 2008
  • 1 more comment
  • mardon35 Oct 04, 2010
    My CP 200, after many years of excellent service, also started printing only on the top half of each print, with the bottom half fading to nothing. Thanks to the photo here I knew what to look for (which was a split in the plastic part on the left side of the shaft). Following this and the other related suggestions such as Solution 1, a drop of Krazy glue solved the problem. I held the split area together with needle-nose pliers for a few minutes while the glue set. So far, so good!
  • KaSiris Xavier
    https://www.youtube.com/watch?v=Cc0OrEiN...
  • KaSiris Xavier
    Here's a video on what i did.
I know the answer to the problem, it's not with the print head, rather it's with the crappy components that canon used.
on all three of my cp printers, there is a small plastic part that is used to press the head agains the paper. the plastic part at the end (right side facing the printer as the usb is on the left side) this plastic part fails along the axis of the rod, giving way to the stress of the print head, this causes the printer to only put the ink down on half the page.
Canon should repair this. I will aggressivly pursue the part from canon.
Harlan Stanley
Austin Texas
Posted on Dec 03, 2007
The super glue fix was great, but I needed to reinforce the white plastic hub. A small tie wrap wouldn't fit, so I used a fine piece of copper wire, about 3 wraps did it. I used 1 strand of a 19-strand #10 THHN electrical wire. Something else may work, but keep it thin.
Another trick is to use baking soda with super glue to accelerate the cure and form a concrete like filler. Make sure the flat on the shaft lines up with the flat spot inside the white plastic hub.
Hope this helps.
Posted on Sep 26, 2008
    Genius:
  • 2,985 Answers
This is a heater breakdown These may help http://www.fixya.com/support/p360580-canon_cp_220_thermal_photo_printer/solutions or go to Canon Tech Help -repair or replacement may be possible.
Posted on May 17, 2007
    New Friend:
I fixed it and made a video which can be seen here on
Canon CP 220 Printer Fix <I am KaSiris>
Posted on Jul 31, 2014
I used super glue, but I carefully spread the crack slightly to try and work the glue between the shaft and the plastic part. Has not hardened yet, will keep you posted. George
Posted on Jan 01, 2010
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
You can "compensate" to some extent for the broken white plastic part by removing the printer cover by removing the four small screws at the four corners on the bottom of the printer and manually applying pressure in the region of the broken plastic part during the four printing passes of the paper through the printer. This obviously does not fix the broken part, but it allows making complete prints even though the part is broken.
Posted on Dec 14, 2009
Just a bit of clarification. The photo of the white part is great but you may have to look very closely at the part. Mine was split underneath so it was hard to see what had happened. The whole part is there but it splits lengthwise and thus won't push the printing mechanism down tight.
Posted on Aug 11, 2008
Galatron and odo, you totally nailed it. I have exactly the same problem and for the same reason. I can't believe canon use these useless plastic components. They **** and I won't be buying a cannon product again. Makes me so angry!
Posted on Apr 19, 2008
Had this same problem with my CP-200. This site was a great resource to finding the source of the problem and fixing it.
I called Canon after reading the first few posts. Don't waste the 40 minutes of your life... they will tell you to ship it in to Elk Grove Village for an evaluation (at your expense.) It will likely cost $89 plus taxes for them to replace this little part (probably with one that will eventually break again.)
I chose the DIY solution... A little super glue and a very thin wire. One loop around the plastic part that has the D shape. This single loop of copper wire was twisted tightly to place constant compression on the plastic around the shaft. Use very thin wire (like power tool windings) and keep it as close to the arm portion of the plastic piece (towards the edge of the machine) as possible. Once I was assured that the wire would not interfere with the rotation of the shaft or surrounding mechanism, I put a few drops of the super glue on the crack. Some flowed into the small remaining crack (capillary action) and some remained on the outside of the plastic to ensure the loop of wire would not move out of place.
Thanks again for saving me some serious dough. Now the printer works like it did before! With a little patience, a good set of precision screwdrivers, and a small needle-nose pliers I was able to turn a small piece of wire and some super-glue into an $89 solution. Good luck!
Posted on Jan 06, 2010
Confirmed that a drop of cyanoacrylate glue (superglue, loctite or whatever) is sufficient to secure the broken cam in place.
Posted on Jul 05, 2008
Just drip a little liquid crazyglue between the shaft and the plastic arm. That's what fixed mine.
Posted on Jul 03, 2008
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon cp 220 only prints 1/2 of the photo
There is nothing wrong with the Printer. The problem is the picture settings that are being used in the graphic software. You have not specified which Graphics or photo software you are using. Therefore I will generally tell you that you have to adjust the size and the dimensions of the photo you are printing. Make the photo small enough that it fits your page. Some graphics software also allow you to crop the photo (which means you zoom on a certain important part of the photo and bite it off and that part is sent for a print to printer). This whole game is in the software. Another important tip is that whatever photo or graphics software you use to print photos, never forget to preview your photo before you send it for printing. The Preview shows you how the overall image will look like after printing.
Dec 09, 2010 | Canon CP-220 Thermal Photo Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Lots of left over paper
Go to this site
http://www.google.com/products?q=cannon+cp-220+printer++ink&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=4&ct=title
Hope this helps. Bud
Jan 06, 2009 | Canon CP-220 Thermal Photo Printer
Check out the cartridge on the Rack moving completely otherwise clean up the Carriage rack,
remove the Cartridge once and then clean it firmly, its Nozzle and contact strip.
Then clean out with a cotton or paper the carriage rack and contract strip, also the Roller (if you are accessible to that).
If no luck then try for reinstall the printer, and use of new cartridge.
Let me know if you need further assistance. Download the Driver using this link:
Canon CP -220
Nov 01, 2008 | Office Equipment & Supplies
Cannon photo printer cp 220
cleaner? as in the electronic version..those printers can get crusty when not used..might be some deposits inside the cartridge carrier area
Mar 20, 2008 | Canon CP-220 Thermal Photo Printer
Canon CP 220- HELP
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=259&modelid=10073 Here is site for your printer. Try unplugging (from the wall and computer)the printer for a few minutes let it clear out the memory etc. Or even download and install the latest drivers. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Canon CP-220 Thermal Photo Printer
Canon CP-220 Thermal Photo Printer Logo
5,108 people viewed this question
old marine
old marine
