My GE electric oven is not working although the surface units are. The clock/time cook pad has no light on. I followed the instructioin in the manual to reset it after a power failure and it still wont work. I also checked the back for loose connections and found none. I tried holding down the clock button to try to reset it with no success. Any further advice is greatly appreciated.
-   Top burners work on my ge profile. None of the keypads will function-   Guest
Oct 30, 2008
-   i have this same problem as first noted above and have replaced the control board called a "t09" and still nothing on control board and no oven but the electric top burners work help please-   jakebtc
Oct 04, 2008
-   My GE Electric oven won't work It was just delivered today ! My surface units work and when I open the range doors the clock flashes. When I close the doors the clock panel is blank. There was no power surge or electric outage. Do you have any suggestions I called the GE help desk and their 1 suggestion (turning off my power for 1 minuted) did not work!-   Tory1
Aug 11, 2008
-   I have a similar problem, clock works, timer works, oven light works , but when I try to use the oven, it displays "unlock door" and the door is not locked at all..... any suggestions ?
-   jinkers
Mar 04, 2008
-   I have Model JGBP79WEW1WW gas Profile. The touch pad is blank and not working or displaying any numbers or error codes at all but, the surface units are still operable.-   Chicagofix
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and...
(More)
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and flames. I immediately turned it off and checked under the top and found the tubing cracked and there was another one cracked too! I need replacement parts and to make you all aware of this danger.
Stove gas turns on and off when preheating. Takes forever to heat oven to desired temp. What do...
(More)
Stove gas turns on and off when preheating. Takes forever to heat oven to desired temp. What do I need to adjust to keep the gas flowing longer to heat the oven?
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried...
(More)
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried the troubleshoot online still not working. what should I do?
