Netgear: Desktop the modem and router are connected to will not allow me to get on the internet, but the laptops work.
  • Dan rogers
    Dan rogers May 11, 2010
    did you look up the network settings on the laptops and make the desktops identical.
  • 26 Answers
The PC needs the right IP address from the router. In Control Panel, select Network Connections. Click on LAN connection. Select TCP/IP and click on Properties. Make sure "Obtain an IP address automatically" is selected and the address of your router (192.168.1.1 usually) is entered as the DNS server.
Another thing you could try is to swap over the cables on the router. (the one to the modem and the one to the PC) then restart the PC.
Posted on Dec 30, 2008
No internet access netgear router
It may be the device you are trying to connect. shut down everything, unplug , remove batteries, plug in the ISP model, allow the self test, plug in the wireless device, allow it to self test, plug in, reboot the device, laptop, desktop, ipad, phone, whatever. You say you can connect using a Ethernet Cable? Just no connection wirelessly?
Apr 06, 2013 | Computers & Internet
Find compatible router
Contact Netgear! Their tech. support number should be in the documentation that came with your router.
May 15, 2017 | Motorola Computers & Internet
How can you use public access on your desktop and netbook with a netgear router and adapter walmart sales lady said it can be done with just the router and adapter setup everything we needed was in the...
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Sep 28, 2010 | NetGear RangeMax Dual-Band Wireless-N...
I purchased the AT&T Motorola modem if I connect my desktop directly it works, but my laptops do not - if I connect my Netgear router my laptops then work but my desktop does not...help...
>in order for you not to have more problems at all
>first, ask AT&T to set your motorola modem to BRIDGED MODE first
>then, connect your Netgear router to the modem
>connect the desktop computer to the router and check you connection
>after you got the desktop computer connected to the internet
>try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | NetGear RangeMax WPN824 Router
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
