Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM wheelwriter 15 Series II not working
Once you cut the machine on the big part in the middles moves all the way to the left hand sides and stops. Once this is done you have the line spacing that blinks on and off and no other movement.
It seems as if the margins are set past the typewriter limits.
  • 475 Answers
If the beeper beeps three times and the line space light start blinking you may need new batteries
Posted on Dec 31, 2008
  • Lexmark Master
  • 3,594 Answers
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
IBM Wheelwriter 15 Series II Type 6783-003. When turned on all lights flash once and then machine shuts off.
dont know. here is the manual http://publications.lexmark.com/publications/pdfs/2007/typewriters/Wheelwriter-15sII.pdf
Oct 03, 2017 | IBM Office Equipment & Supplies
Wheelwriter series II when I hit return the
The silver shaft that the carrier slide on needs a little lube WD40 works well. Also check for any deprid under the carrier that could interfere with its movement.
DickyO
Dec 26, 2009 | IBM Office Equipment & Supplies
IBM wheelwright 15 series 2
Try puting some light oil (WD40 works well) on the silver shaft that the carrier slides on, also check for debris it that area.
DickyO
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 15 won't get past lights coming on
Be sure the printwheel is proprly installed, Check the keyboard connectors and look for debris in the P/W area.
DickyO
Mar 28, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Carriage will not return
the silver shaft that the carrier moves back & fourth on is gummy take a rag & put some light wait oil on it wipe the silver shaft down. With the power off move the carrier back and fouth. spray or put on more oil on shaft wipe down any extra oil.
Jan 22, 2009 | Lexmark Wheelwriter 15 Series II...
Hums, but no light and can't type
Turn the T/W off and see if the carrier will move freely back and forth. if it won't try some WW40 on the silver shaft it slides on.
DickyO
Aug 25, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
131 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
