Monitor says no signal
When I boot up my computer the Monitor says no signal, The computer lights are on.I turn the power strip off.The computer and Monitor turn off and then I turn the power strip back on and the Monitor and Computer turn on with out a problem.Sometimes I have to do the above 2 or 3 times.This only happens in the morning when I boot up my system.I think its a Computer problem and not a Monitor problem, The same thing happens when I had my old CRT Monitor hooked up.Can you please tell me what the problem is?Thank You
  • RBlank111 Dec 30, 2008
    No the computer does not beep at all.I bought the system in January 2008 and this has happened sense March or April. I hope this helps.Thanks knotbeerdan
  • Dan rogers
    Dan rogers May 11, 2010
    does the computer beep several if at all when this happens?
    How long has this been happening
    Novelist:
  • 124 Answers
Is this a brand new system? What is the make/model?
This is a peculiar problem, as the computer was working fine for several months after you purchased the computer, then suddenly started this behavior. The fact that you do establish normal operation after the restart eliminates a few culprits. Your monitor is perfectly fine, as you eliminated that by trying another (same problem). I doubt the problem is your BIOS, as the OEM BIOS is usually a very solid part of the system. Unless you updated it in March/April?
The hardware should be fine--if there's a hardware problem, usually it works or doesn't work, or will work intermittently in an unpredictable manner (meaning, you'd start up and everything would be fine, but later on the video would cut out).
Also, try this experiment: When you start up the computer and you get the "no signal" indicator on the monitor, shut down the computer and leave it off for about 5 minutes. Start it again. If the problem repeats, it could be that there's some kind of software conflict between the operating system and BIOS, but a warm restart bypasses this.
It is possible that a Windows update that occurred around March/April may be conflicting with a driver or the BIOS. There are a couple of things you can try... In the "Accessories > System Tools" there is a System Restore utility. If you haven't made many changes to your system since March/April (e.g. installed a lot of device drivers, components, software), you could try restoring to a point where you are certain the problem wasn't occuring. If that works, you know that a software update is the culprit. If it doesn't, don't worry--you can "undo" the restore and go back to where you were so you don't lose other things you've installed (your registry gets updated frequently over time and you don't want to lose that).
There may be an updated BIOS for your computer as well. If you bought it new, it doesn't guarantee they had the latest installed when you got it.
Posted on Dec 30, 2008
    Master:
  • 413 Answers
You should try resetting the BIOS (either by changing the right jumper, or by pulling out the CMOS battery, or whatever religious ritual your brand of motherboard requires, such as sacrificing a chicken on the keyboard), because it sounds like you've got a problem with one of the busses (e.g. the PCI bus, the AGP bus, the Chicago-bound Bus, or whatever). It may only be a software problem, which you might be able to get rid of by resetting the BIOS; but if your computer still displays the same vital signs as an ashtray, then you've got a more serious problem on your hands. Post back here and we'll see then.
Nothing displays on the monitor when I turn on the computer
is there power to the monitor? is the monitor in standby(yellow light on monitor)? is the monitor on (green light on monitor)? how is the monitor connected to the computer, VGA (square fat cable, the end may be blue) or HDMI cable? When you turn on the computer is the power light on and HDD light flashing / showing activity? this would indicate that the computer is booting up. If you have power light and activity on the computer, I would unplug the data cable to the monitor. If the monitor is plugged in, i would press the power button to try and turn on the monitor / take it out of standby. If the monitor is ok you should see a message like "no signal" or "no input". This would tell you that the monitor is fine, but you may have a problem with the video card or video port on the motherboard. If you have no activity light on the on the computer, you may have a problem with the OS not booting up. You really didn't provide much detail on what has been done, but this is how I troubleshoot out in the field when working on something like this.
Oct 09, 2013 | Computers & Internet
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
My computer will turn on but my monitor does not get a signal and I've tried this on two working monitors and two different power chords. The lights on the keyboards don't even work. Any solution?
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different computer...it too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at zipzoomfly.com or newegg.com
May 20, 2010 | E-Machines eMachines Desktop PC
My ADC monitor will not come on but the power light flashes yellow. Does this mean my monitor is shot? Is there a way to check it? The power adapter is still putting out 12 V. Thanks, Bob
Flashing yellow light usually means it is not getting the video signal from the PC, try it on other PC first to narrow it down the problem, bad VGA cable can also be the cause, last will be problem in the monitor itself which you will need to open up to inspect the inside. Post back what you find so we can helpou more. More likely to be bad backlights inverter board.
Mar 05, 2010 | Computers & Internet
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Monitor and keyboard won't turn on
A couple of things here:
1) The flashing light and signal message indicate that the monitor is functioning but is not receiving a signal from the computer.
2) The memory that you added is liklely to be incompatible with the computer itself and is preventing the system from booting. The computer will perform a selftest when powered on. Normally when there is a memory issue, the unit will beep. In some cases, there will be no action.
Remove the added memory and attempt to boot the system. If it starts up OK, then the memory you have added is the problem.
Update this if you require additional assistance.
Thanks,
Dan
Apr 15, 2009 | Computers & Internet
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Monitor Start up
It is the same problem I experienced and now it suddenly stopped and dead.
what the manufacturer of the unit has to say about inherent design fault which they are liable under UK consumer law to rectify within 6 years
And incidently who are manufacturer to this Licon make is please
Jun 29, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
