Question about Alcatel Newbridge MainStreet 2902 Multiplexer (90-2904-01)
Power Consumption Operational Value?
Does anyone know the power consumption for this device (wattage or amperage)? All I can find is a voltage value (90-240V). Thank you.
  • Michael Lucas
    Michael Lucas May 11, 2010
    Do you have this info
    Power
    Power Device: Power supply - internal
    Voltage Required: AC 110/220 V ± 10%
    Frequency Required: 50/60 Hz
    Scholar:
  • 108 Answers
This is what you want to know. Copy and paste this address.
http://www.voxtechnologies.com/alcatel/pdf/ms2902.pdf
Posted on Jan 16, 2009
Need the manual
All domestic appliances have a rating plate which informs you of the voltage, wattage and energy rating. Its the wattage that will give you a rough theoretical idea of the power but in reality it only applies to the power consumption of the item not its actual sucking/pick-up rate.
Oct 17, 2014 | Vacuums
What is the difference between volts and Watts
Volts is best thought of as the "speed" at which electricity is traveling. Wattage on the other hand is a measure of how much electricity is consumed over a certain length of time. This is why the wattage is listed on light bulbs, because it involves power consumption and your electricity bill. Volts on the other hand are a requirement for compatibility with various devices. If you plug a 110v device into a 240v power supply you're going to have a bad time. Many high tech electrical devices these days have on board transformers and will accept a wide range of voltages.
Oct 14, 2014 | Electronics - Others
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
What is the power consumption for a pixma mx 350 printer
Power consumption in operation is 12 W. Click here for further details
HOPE IT HELPS!
CreativeTECH
Nov 23, 2010 | Canon PIXMA MX350 Wireless All-in-One...
Which power supply box goes to the HP scanjet 2200c?
It should give the voltage/wattage on the scanner and the power supply.
Voltage Required AC 110/220 V ± 10%
  • Power Consumption Operational ( Standby ) 19 Watt ( 6 Watt )
  • Jul 22, 2010 | HP ScanJet 2200C Flatbed Scanner
    I need the value of resistor R1 on my model
    Hi. I have access to the Service Manual for this model, the only technical information it provides is this:
    - Voltage : 100-240 V AC 50-60 Hz
    - Power consumption : Motor depending
    - Motor Voltage : 1,2 V
    - Power system : Rechargeable
    If you have no luck, Part No 4222 036 09060 is for the PCB.
    A copy of the Service manual was found also at http://www.shop-stecken.de/ecarusShop/v30/pdf/HQ6613.pdf
    Nov 30, 2009 | Philips Health & Beauty
    I require a step down plug
    I'm disappointed that Dewalt does not have the full specs on their website so . . .
    Check the specifications on the charger's label; they should read something like 120 VAC or Volts AC and 2.0 (or similar) amperes or just 'A' after a numerical value.
    If the label does not give you an amperage value you can use the output value instead and substitute the output voltage at the high end if a range is listed.
    To get the adaptor (step-down transformer) wattage, multiply the AC values such as:
    120 X 2=240 watts input power.
    If these AC values are not available;
    Take the high end charge voltage if it is a multirange charger, and multiply those values;
    One we own DW9108 (- yours is 7.2 - 18) is spec'd at 9.6 to 18 volts and 2.8 amperes:
    2.8 X 18=50.4 watts.
    You can see that the values do not correspond but it is a multirange device so the maximum current taken from the AC line can be ~ 2.0 amperes but this is charging a specific pack and the peak input current is only momentary so the maximum output current and voltage are the values one should use as a guide. In other words, the output wattage is closer to the value needed.
    Since there are losses in any transformation (mostly heat), the required stepdown transformer must be capable of more than the indicated 50 watts.
    A safe factor would be 1.5 X 50 (W) or ~ 75 watts minimum to ensure the charger receives the 120 volts it wants.
    Anything that will step down your (?) 220 volts and is rated at 75 watts or more will do the job even if the Dewalt draws a little more current at your line frequency of 50Hz which it may.
    Oct 09, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
    Entrega Hub 4U
    The adapter that works on my machub4u y Entrega Technologies has a output of +5VDC at 2.5A with the inner post being positive and the barrel being negative.
    Sep 01, 2008 | Entrega (HUB-4U) Networking Hub
    Alcatel Newbridge MainStreet 2902 Multiplexer (90-2904-01) Logo
    910 people viewed this question
    Top Alcatel Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Thomas Perkins
    Thomas Perkins
    Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
