Question about Microsoft Xbox 360 Console
X box 360 console
There are 2 red lights flashing and it will play most movies but no and the power cord stays green
  • skingfisher1 Dec 30, 2008
    doesn't play at all
    Sergeant:
    Champion:
  • 378 Answers
Most of the time when you have 2 red flashing lights one of the clamps has come loose holding down the cooler on the GPU or CPU.
Posted on Jan 01, 2009
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
Well mainly it is down to overheating, and as you play your games the motherboard flexes ever so slightly and the soldering snaps off and that is when you are left with the red lights of doom.
Step 1: Turn on the console, and check the light on your power supply
The power supply light is located on the black box that is in the middle of your power cord.
Step 2: If power supply light is green, try this solution
Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions:
Solution A: Unplug your console, plug it into a different outlet in a different room, and then turn it on
This will help determine whether the problem is with your power supply, your power outlet, or your console.
Solution B: Request a replacement power supply
If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Mar 27, 2010 | Microsoft Xbox 360 Console
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
