Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a mitsubishi 52525 I am at the menu screen and the antenna icon is not accessible
  • 179 Answers
You either need to add it with the netcommand function, or reset the set with "menu 2470 enter"
Posted on Dec 31, 2008
My screen has multiple vertical black lines accross the screen. They are about 1" appart
I've had the same problem but with green lines. I thought it was the HDMI cable but it's the same with all the inputs.The only one that works is the over the air antenna. Check your over the air antenna.
Aug 15, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Turned on my Mitsubishi WD-52525 this morning and none of the on-screen displays are working. Picture is fine but volume control doesn't show on screen- it does adjust though, can't access menu or at least...
I usually do not give a one line answer but here is what I would try if I were you:
With the set on and using the original Mitsubishi remote:
MENU, 1, 2, 3 ENTER.
This is the soft reset for the set--it will or should shut off and come back on--you may have to autoprogram it etc.
There is also a HARD reset that returns the set to the condition it was when new in the box.
Try the soft reset and see what happens.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Cannot hook up my playstation2 to my mits wd 52525
on the set you have to go in to the menu and turn on those port so you can play. it should be under inputs the turn on the one you are using. if that dos not work let me know.
Aug 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
