Question about Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever ....
Pressure problem with Kohler shower faucet??
We have a kohler faucet and shower head. When we turn on the faucet for the shower the water pressure seems very strong when it is in the cold water position-when we proceed to move the faucet lever to hot the pressure decreases and the water coming out is minimal-any ideas what is going on?
    Scholar:
  • 68 Answers
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
2 Suggested Answers
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
Low water pressure from my shower.
You probably have a water flow reducer in the shower head. It is a rubber disk with a few holes in it. Just remove it and put the shower head back on. They are installed at the factory to save our environment. (Mine are all removed)
Dec 05, 2012 | Kohler Home
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
High pressure
Are you sure it's not just that the shower heads are getting dirty from calcium build up, thus reducing the diameter of the holes in the head, which will in turn cause spray to come out at higher pressure. ( same idea as holding your thumb over the end of a garden hose) Try removing and either replacing head, or soak it overnight in C.L.R (available at any hardware store.) and clean it good and try it again.
Apr 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
When we turn on the water the hose turns to the right. how can i fix it
this is due to the high water pressure !reduce the pressure on your valve
Nov 11, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever .... Logo
1,249 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
