Question about HP Pavilion dv8000t Notebook
Windows xp color problems
I have a HP dv8125nr laptop and something has caused the basic color pallet to change. I appear to have red & white, strips where I should have a solid background color. It also comes in on the internet windows. The window I'm typing in now has the same background.
I have attempted to change the setting in the control panel on the display settings, but have not solved the problem.
can anyone tell me how to restore the basic widows xp color palet.
I have also tried to restore the system to a date prior to the problem, but it does not clear this problem.
  • 916 Answers
If you have a video card mounted in a PCI or AGP slot, take that out, blast the slot and the connector on the video card with compressed air, and put it back in.
If you're using motherboard-integrated graphics, do the same thing as above to all of your memory (RAM) modules. Also run memtest86 from a bootable floppy or CD. If it comes up with even just one error, you'll need to replace some RAM. Integrated graphics use system RAM as video memory, so faulty memory can cause the display 'artifacts'.
Posted on Jan 01, 2009
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
Change the font size
For Windows XP : Right Click on Desktop--> Properties--> Appearance--> Font Size, here you can able to change the size.
For Windows Vista :
  1. Right-click the Desktop background, and click Personalize .
  2. If a "Window Color and Appearance" window opens, click Open classic appearance properties for more color options . The Appearance Settings window opens.
  3. Click Advanced . The Advanced Appearance window opens.
  4. Advanced Appearance window showing icon font size settings.
Select the required font and press OK. For Windows 7: Please click on the below link to view how to change the font in Windows 7. Change Font Settings . Please let me know the status. Thanks for posting to FixYa.
Feb 12, 2011 | HP Pavilion dv6000z Notebook
We bought a HP Pavilion DV-7 two days back. Now we find that often the screen flickers in such a way that white colour on the screen (regardless of whether it's in a specific application window, or the...
Changes in color in a laptop or a desktop screen from white to cyan are due to a malfunctioning cable. There is a cable that goes from the screen to the motherboard under the keyboard.Heat, movement of the screen etc will cause this. You should return this item and get another. This is especially important since you have only had it two days. Something went wrong in the manufacture of this laptop. All companies have a 30 day replacement policy and you would be smart to get this one swapped out as soon as possible.
If you like my answer, please accept it. PCTechsOnline
Dec 24, 2010 | HP Computers & Internet
OUR HITACHI 50V500A HAS COLOR PROBLEMS WE MOVED IT
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Hello i have a problem with my laptop i have pink color and green color on the screen all things in black are covered with green
The display is gone. Replace it. You see the basic Red-Green-Blue pallete... The liquid chrystals are "broken down"
Nov 29, 2009 | ASUS S6 Notebook
I have done something but i dont know what i did (something on personalise) but everytime i go on the internet and the background is supposed to be white in space, but it is now white how do i change it...
In case using windows XP, right click on the empty space in the desktop and select Properties, Display Properties shall open up. Go to Appearance tab and click on the Advanced button. In the Item dropdown box select Window and make sure that color 1 is selected as White and Color 2 as Black.
Please rate this solution in case it works for you, it helps us in assisting users like you. In case the problem is still not resolved, do not rate thesolution, leave a comment instead and we shall assist you further.
Nov 11, 2009 | HP Pavilion zd7020US Notebook
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
DISPLAY
Your phone's screen connectors might have a problem and need to be replaced by new ones or they need to be placed correctly. this might have happened due to a fall of your phone on the ground.
Oct 07, 2007 | Nokia 6670 Handheld
HP Pavilion dv8000t Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
