Question about Sony Handycam DCR-IP7E Micro Digital Camcorder
Tape compartment will not close
I have a Sony DCR-IP7E camcorder and I have ejected the Micro MV tape to put in a new one and the tape compartment will now not close. The camera is fully charged, can anyone come up with a solution?
  • mfowmes May 04, 2009
This happened to my sony DCR-IP7E, I had to have this repaired by a camera shop of £129.00 with 12months gtee, work like a new one
Posted on Jul 20, 2009
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Dub a tape that is playing through my camcorder on TV
A vcr or dvd-recorder only reads the input signal. It does not care where it is coming from, only that it is there. You would have to run it through the vcr or dvdr for it to read the signal, or copy it to your computer and burn it to dvd.
May 27, 2009 | Sony Handycam DCR-IP7E Micro Digital...
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 03, 2007 | Sony Handycam DCR-TRV250E Digital...
Sony Handycam DCR-IP7E Micro Digital Camcorder Logo
236 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
