Question about 3Com OfficeConnect Wireless 11g 802.11g/b (3CRWE154G72)
XP compatable where can i download an xp compatable install programme 4 a 3com office connect 11g pc card (3crwe154g72). tried 3com!
  • 611 Answers
Then you have to used the wireless g router for wireless
Posted on Dec 31, 2008
Tip
Compatibility Pack for MS Office, doc to docx, ppt to pptx, xls to xlsx
This tip is all about the compatibility issues between the Office 2000, Office XP, or Office 2003 with Office 2007. Because all programs in Office 2000, Office XP, or Office 2003 used the old file extensions for its different programs. For example Word 2000 saved files with extension .doc, Excel 2000 with .xls and PowerPoint 2000 with .ppt. but on the other Office 2007 used the new file extensions for its different programs. For example Word 2007 saved files with extension .docx, Excel 2007 with .xlsx and PowerPoint 2007 with .pptx. Now the problem is that when you will try to open Office 2007 files into Office 2000, Office XP, or Office 2003 you will not open the file due to compatibility issues between both office versions (before 2007 and after 2007). Microsoft provides a free compatibility pack to convert Office 2007 documents to the Office 2000, Office XP, or Office 2003 format. There are many third party free converter are available but here we are using Microsoft office compatibility pack.
Please follow the given link to download free Microsoft compatibility pack -
http://www.microsoft.com/downloads/details.aspx?FamilyId=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Just install the compatibility pack after downloading........
on Mar 02, 2010 | Computers & Internet
Windows XP compatibility
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 01, 2012 | Cameras
My files from ms word 2007 won't work on other PC using xp operating system
It may be just that they have an older version of MS Office, try downloading and installing the Microsoft office compatibility package, its free
:- http://office.microsoft.com/en-us/support/microsoft-office-compatibility-pack-for-word-excel-and-powerpoint-2007-file-formats-HA010168676.aspx
If the url doesn't work just google
Microsoft Office Compatibility Pack.
If that doesn't work, don't pay MS anymore money. Go to Filehippo.com download and install "Open Office" its also free and you can read and write MS office compatible docs.
Mar 29, 2011 | Microsoft Office Professional 2007 Full...
I just downloaded the windows 7 upgrade on my acer netbook and now I can't get my wireless connection to work. (the old OS was XP) I have tried re-installing the driver but no luck! Help!
Please explain the issue a bit more.
Are you not able to find the wireless signal at all now or they are visible but you are not able to connect?
If they are not visible, then have you checked the device manager and see if there is any wi-fi card mentioned under Network Adapters or not or is there any question mark or exclamation mark on it or not?
Feb 13, 2011 | Acer Aspire One Netbook
3COM PC Card model 3CRWE154G72 Error code 10: device cannot start
a windows file or files is definitely corrupt,either repair windows xp with service pack3 if possible or do a complete format and re-installation.,and the card should work fine
Nov 24, 2009 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Help I just reinstalled windows XP Home and office 2003. When I try to install my proofing tools 2002 (which have always worked) the programme stops installing saying it can't find office XP. Can any one...
Office XP has to be installed for the proofing tools 2002 installation. Apparently you had Office XP installed and Office 2003 will work with prior versions of office software. Try re-installing your Office XP software.
Feb 26, 2009 | Microsoft Office Proofing Tools 2002 for...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
3Com OfficeConnect Wireless 11g 802.11g/b (3CRWE154G72) Logo
256 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
