COMPUTER WONT LOG ON JUST INSTALLED A BELKIN WIRELESS ROUTER
  • 2 more comments
  • alialvee May 11, 2010
    Restart PC in last known good configuration or Safe mode by pressing F8 key during reboot and check you are able to logon or not if still not try safe mode again sure you will get logon and from control panel remove application you install for belkin wirless router....
  • Michael Krout
    Michael Krout May 11, 2010
    What Operating System are you running? Are you connected to a Cat5 cable or Wireless adapter?
  • SoleAngelus May 11, 2010
    Does the computer boot up? How do you mean it doesnt log on?
  • Frank
    Frank May 11, 2010
    more detail please?
  • 103 Answers
Software conflict check the Operating System you are using and see whether the drivers of the belking wireless router is compactible with the OS if not download a siutable driver for your router to work
PS. what ever you do you need to re-install the OS
Posted on Jan 02, 2009
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
My router does not show wireless signal just wired
Your computer cannot detect the Belkin if the wireless card in the computer has not been configured with the Belkin wireless settings.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 24, 2010 | Belkin N1 Wireless-N Wireless Router
INSTALLED DISK BUT IT GIVES ME WRONG PASS CODE WHEN I TRY TO LOG IN ON MY LAPTOP. i AM USING THE CODE THAT CAME WITH THE ROUTER AND HAVE CHECKED MANY TIMES AND IT IS CORRECT. IT SHOWS AVAILABLE BELKIN ON...
hi,
Reset your router will help you.. Resetting will cancel your all configurations. and will accept your default password and user name (i.e. admin) After resetting config your router again.
Hope this has helped you thanks
Jun 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin n wirelss router setup
I made a video on how to do it on my F9K1003V1. It should be close to the same setup. The IP address you use to log into it should be the same as I use in the video but the menu will probably be a little different.
Feb 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Will not log on to internet
belkin router F5D7230-4
wireless works fine, anything plugged in gets cut off after a few minutes.
Dec 14, 2008 | Belkin (F5D7230-4) Router (587009)
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Belkin F5D8233-4 router & I pod touch wifi
What I would try is while the wifi is unsecure go on the computer and open up the browser you are using, on your router the default ip address is 192.168.2.1moz-screenshot.jpg
type the router default ip address in the browser where you would normally type a web address www.google.com
Logging into the Router
You will see the Router’s home page in your browser window. The home page is visible to any user who wants to see it. To make any changes to the Router’s settings, you have to log in. Clicking the
“Login” button or clicking on any one of the links on the home page will take you to the login screen. The Router ships with no password entered. In the login screen, leave the password blank and click the
“Submit” button to log in.
Configuring the Wireless Network Settings
The “Wireless” tab lets you make changes to the wireless network settings. From this tab you can make changes to the wireless network name or Service Set Identifier (SSID), operating channel, encryption security settings, and configure the Router to be used as an access point.
Setting up an Allow Access List
1. Select the “Allow” radio button (1) to begin setting up a list of
computers allowed to connect to the wireless network.
2. Next, in the “MAC Address” field that is blank (3), type in the
MAC address of the wireless computer you want to be able to
access the wireless network, then click “<<Add” (4).
3. Continue to do this until all of the computers you want to add
have been entered.
4. Click “Apply Changes” (5) to finish.
this will allow only the wireless device you select to access your router.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
